586,075 active members*
4,014 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > OMAG Mill98 / NUM 1040 System SRAM issue
Results 1 to 6 of 6
    Good afternoon all, I'm taking a shot at getting an answer for this, but, I have an OMAG Mill98 with a NUM1040 controller that I'm having an issue with. It's giving me the following error message on powerup:
    error found on SYSTEM RAM header's checksum !!!
    checksum found = 00014040, checksum obtained = 00044F4E
    pointer's SYSTEM RAM obtained = 7B6FBF5F 0F100503 53EFFFFF 9D010A04 00104040 FFFFFFFA
    Ready to clear Systeme SRAM ? (Press any key to continue) :
    http://www.cnczone.com/forums/attach...d=325188&stc=1
    If I press any key on the control, it tells me wrong answer, please retry.
    Any clue what's up here? Are the RAM modules no good?
    Re: OMAG Mill98 / NUM 1040 System SRAM issue
    The first line was missing, because I had tried to press "any key" to proceed. It says "global reprom programs execution"
    Sep 2016
    3
    Hi. This is a "simple" one
    The RAM modules are probably perfectly OK. The problem is that your battery has failed.
    You need to replace the battery 0297900000 and then re-load the backup from your archive... Hopefully you have a backup, if not you will just need to contact OMAG and give them your machine serial number and affaire number of the CNC
    Sep 2016
    3
    Oh, and you have to answer with either Y for yes or O for yes in French
    Mar 2014
    3
    Hello!
    Finaly how do you solved the problem?
    .... because I have same problem!!!:<
    Best regards,
    Traian.
    Jul 2023
    Same here, any help would be apreciated. I know i have to replace the batteries, my question is, how do i reload backups if the machine doesnt boot?
  1. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  2. bavelloni, cms, omag
    By Nick marble in forum Glass, Plastic and Stone
    Last Post: 10-26-2015, 08:07 PM
  3. CF card SRAM backup/Restore issue
    By elab.ess in forum Fanuc
    Last Post: 04-21-2013, 01:38 AM
  4. SRAM backup VS System data save
    By fomaz in forum Fanuc
    Last Post: 05-02-2012, 09:26 PM
  5. Chick System 5 vise 1040
    By walter_58 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-25-2009, 05:02 AM
