Hello,
I am trying to nest 5 different size panels into a 4x8 sheet of 3/4 maple veneer. I use the nesting drop down, pick my parts and tool paths from screen, apply to panel-all is well. When I try to run, the program allows me to cut out the parts on the bottom (x Axis). When the router traverses to the parts above them (y axis) I get an error code n 70 pgp if circle programmed by its radius and end point. Any ideas? My parts are all rectangles, cutting with downshear .4145 diam solid carbide bit. Also, any thoughts on a good chart for rpm and speed for different tools and mtls?
Benaiah
