586,115 active members*
3,340 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas TM 2P making noise in the Z axis
    Jun 2016
    New beebie here,
    what would cause the Z axis to make noise only when using 100% rapid? Hoping its not the ball screw but maybe the belt. I grease the machine once a month with Haas grease.
    Thanks in advance.
    Scott
    Oct 2015
    32
    Re: Haas TM 2P making noise in the Z axis
    I don't believe the Z axis is belt drive on TM machines. I would suspect the thrust bearings if the noise is only present at 100% rapid. It could also be a ballscrew but the thrust bearings are much cheaper so I'd start there.
    Oct 2011
    106
    We had that on our VF1 and it was the ball screw. It slowly stared to get worse so you could hear it when it was moving at lower rapid speeds. It makes a lovely noise at 25% rapid.
    Sent from my iPad using Tapatalk
  1. Replies: 7
    Last Post: 08-14-2020, 02:13 PM
  2. Replies: 3
    Last Post: 09-06-2013, 03:30 PM
  3. Z-Axis making noise
    By 2Bits in forum Linear and Rotary Motion
    Last Post: 06-14-2011, 02:15 AM
  4. motor making noise
    By kasari in forum CNC Machine Related Electronics
    Last Post: 01-17-2010, 01:33 AM
  5. Lead screw making noise
    By clembrant in forum Linear and Rotary Motion
    Last Post: 01-27-2007, 04:48 PM
