586,103 active members*
3,859 visitors online*
Results 1 to 7 of 7
    May 2016
    15
    timing belts and pulleys for CNC
    Can anyone recommend a US supplier for timing belts and pulleys with reasonable prices? Anything I should look for in particular?
    Adam
    Re: timing belts and pulleys for CNC
    B&B Manufacturing.
    That would probably depend on the specific application. Belts and pulleys are used for many different things.
    May 2016
    15
    Thanks Gerry,
    Using them to drive ballscrews from my stepper motors (570oz)
    Apr 2004
    5737
    Are you reducing/increasing the speed, or just transferring motion? If you use it to reduce speed, in hopes of getting more torque, you're going to be disappointed, since steppers have less torque the faster they run. If you're trying to increase the speed this way, you lose resolution. If all you're doing is transferring motion, you can do that easier with spider-type couplings.
    Andrew Werby
    Website
    May 2016
    15
    Thanks Andrew. I'm not looking to change any ratios, just fold the system on itself so I can align the steppers parallel to the ballscrews and not have them sticking out from the machine.
    Jul 2010
    172
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
    24221
    I get mine from a visit to a local bearing supply house, they often either carry them or can bring them in from their supplier.
    Al.
    Albert E.
  1. Where are you getting your timing belts/pulleys?
    By Wallybanger in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2014, 09:54 PM
  2. timing belts and pulleys
    By neurofen in forum Linear and Rotary Motion
    Last Post: 02-08-2011, 06:55 PM
  3. Timing belts and pulleys
    By tt-boy in forum Hobby Discussion
    Last Post: 08-11-2009, 01:35 PM
  4. Timing belts and pulleys?
    By Jack Aubrey in forum Linear and Rotary Motion
    Last Post: 01-12-2008, 11:41 AM
  5. What pulleys and timing belts do I buy from sdp-si???
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 12-05-2005, 12:06 PM
