586,358 active members*
3,567 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > HI CELL CA23B Alarm 1466 "Chucking of work abnormal"
Results 1 to 8 of 8
    s00073055 Guest
    Where do i start looking for the cause of this alarm any suggestions would be great thanks
    Dec 2009
    539
    Re: HI CELL CA23B Alarm 1466 "Chucking of work abnormal"
    Well, not to be to obvious, but is the key for the chuck in the right direction?
    John
    s00073055 Guest
    Key is turned to internal tried it the other way as well no difference I have a ? Will the machine alarm if there is no chuck fitted to the sub spindle side. Thanks
    s00073055 Guest
    Alarm 1466 gone prox. switch. new problem 948 E.Stop alarm will not clear and the hydraulic pump not starting
    Dec 2009
    539
    Quote Originally Posted by s00073055 View Post
    Before were you able to get into standby?
    s00073055 Guest
    Quote Originally Posted by shas595 View Post
    Not able to get into standby. Thanks for the quick reply
    Dec 2009
    539
    what is the control on your machine?
    s00073055 Guest
    Seicos III
  1. "abnormal coolant"??
    By jay_dizzle in forum Fanuc
    Last Post: 12-23-2020, 08:55 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Replies: 2
    Last Post: 02-04-2015, 11:59 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. "abnormal coolant"???
    By jay_dizzle in forum Okuma
    Last Post: 01-21-2011, 06:26 PM
