586,069 active members*
3,471 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Nema 23 stalling at faster speeds, 24v Versus 48V Difference in torque?
Results 1 to 18 of 18
    Aug 2015
    45
    Question Nema 23 stalling at faster speeds, 24v Versus 48V Difference in torque?
    Hi guys uim building my second cnc machine at the moment.
    The machine is 3 axis with 4 steppers (2 on the y) The steppers are nema 23s.
    I didnt notice this issue on my last machine but with this one i am noticing it now.
    THE ISSUE:
    If i increase the rapid speed to anything greater than 1200mm/min the motors stall at certain points along the axis. I then decided to remove thethe rails and just see if it was a load related issue. at this speed i can simply squeeze the ballscrew as it turns with my fingertips hardly any pressure and make the motors stall.
    Here are the details:
    At the moment i am using a all in one controller with built in display. it can handle 16v - 36v for the input
    Steppers:
    200 steps per rev
    Ballscrew
    5mm/rev (1605)
    Resolution 1/2
    so 80 steps per mm ( i think)
    The power supply is a 24v 10 Amp
    I was reading the sheet for the steppers and it says power input is 24v - 48v
    My question is mainly will there be much of a difference in any of torque at higher speeds running say even 32v at the same 1200mm/s versus leaving it at 24v @1200mm/s
    If i have to upgrade the controller to a 48v capable or (50v) i will do so but dont want to do that if its not going to make much if any difference
    Any input or link to other reading on the matter would be appreciated.
    I have had a look around but couldnt find anything giving say a greater comparison on the specific steppers only general speed vs voltage vs torque graphs with little to no difference or great difference depending on the model and none on the same model as mine.
    Cheers, Darcy
    Aug 2004
    244
    Re: Nema 23 stalling at faster speeds, 24v Versus 48V Difference in torque?
    Short answer is yes more voltage will increase the torque at speed, the long answer may be found by reading this https://www.google.com/url?sa=t&rct=...Kcn1jsY0zSLLKg
    Everything in moderation, including moderation.
    Doubling voltage can give roughly double the speeds.
    But it may not be worth it, depending on the motor specs. 1200mm/min is very slow, and even doubling that is not very good.
    Apr 2004
    5737
    If you share the motor's spec sheet with us, it would be easier to say what sort of speed you could expect at what voltage, and how much torque you'd get at that speed. But yes, 24v is on the low side for most 23-frame motors.
    Andrew Werby
    Website
    Aug 2015
    45
    Quote Originally Posted by eman5oh View Post
    Thankyou! will have a read later today!
    i was happy enough with 1200mm for rapids so if i can get 1800 or so for rapids even 2000 id be extremely happy
    Quote Originally Posted by awerby View Post
    The motor model is: 23HS41-1804S
    Some info:
    Step Angle 1.8°
    Holding Torque 2.4Nm(340oz.in)
    Rated Torque 1.92Nm(272oz.in)
    Rated Current/phase 1.8A
    Phase Resistance 2.75ohms
    Recommended Voltage 24-48V
    Inductance 17mH±20%(1KHz)
    Weight 1.5kg
    this is the only sheet i could find
    http://www.omc-stepperonline.com/dow...HS41-1804S.pdf
    Cheers
    Aug 2015
    45
    oh and the board im using for control is this at the moment had from my last one so thought id try it before upgrading anything
    4 Axis CNC TB6560 Stepper Driver Aluminium BOX SET Manual Controller Display | eBay
    was thinking of getting this maybe as can handle the 50v
    4 PCS Stepper Motor 5A Driver Controller 5 Axis Breakout Card CNC Router KIT | eBay
    Would it be worth the upgrade?
    Cheers
    1943
    First off, the TB6560 is pretty sub-standard. You can get them to work but other options are soooooo much better.
    The motor you have has 17 mH inductance. Using the commonly accepted formula for optimum voltage for that inductance yields SQRT(17) + 32 = 130 volts. High inductance hurts high speed torque and performance.
    Aug 2015
    45
    Quote Originally Posted by 109jb View Post
    Hmm I knew the board is had was a cheapy. Would the other set it linked do better with a 48v supply based on the motors I have? Still on a budget so I don't want to replace all motors and controller. Would there be a noticeable difference in torque at speed running the new controllersite linked above at 48v instead of 24v do you think? Or would the gain be minimal?
    1943
    Read "Step Motor Basics" at this link Applicaton Notes | Step Motor Controls
    Basically - Yes, increasing voltage will increase high speed performance.
    As for the drives you linked, I personally have not used those drives, but they are TB6600 based drives and there is a link on here somewhere that describes a design fault in them. They still work, but not as well as they should. I don't remember the specifics, but I would not recommend them based on what i have read. There are other TB6600 drives that reportedly are decent and would be better than the TB6560.
    Aug 2015
    45
    Cheers thanks for the help I'll have a search around and see what tb6600 is the recommended one. Thanks again
    Apr 2004
    5737
    The super-high inductance of those motors is what's causing your stalling. As was pointed out above, they really want 130v to perform optimally. At 24v, they're just limping along. While upping the voltage will help, you've got a very long way to go before you're in the sweet spot for those motors. And in the meantime, you'll blow up your crappy drives with the extra power. I'd say throw out all that junk, get a Gecko G-540 and some motors with 2.4 mH inductance, run the system at 48v, and you'll be amazed at the difference.
    Either that, or send more money to China, get more garbage in return, and see how much you end up saving...
    Andrew Werby
    Website
    1943
    Actually, you can get decent drives from Xchina. I have kl-6050 drives from automation technologies and they work great on my G0704 mill running at 180 IPM on 0.2" pitch balls crews. I also have some other tb6600 drives that seem good, but I have yet to fully test them, so don't want to give a thumbs up yet.
    Leadshine also reportedly makes nice drives, and are made in China. Lots of guys using the MX3660 love them.
    The geckos are also good although higher priced.
    I agree though that you I'll have to ditch the motors. The inductance is just too high. High inductance means a low speed motor. Would probably be ok for a belt drive machine, or a rack and pinion machine, but not a lead screw machine.
    Jun 2014
    777
    My advice would be to avoid tb chip drivers all together. They put more energy into making heat that they do the motors. Go for some mosfet drivers, Wantai do some budget ones that are pretty much the same price as tb6600's but miles better, They Run cool. Output the amps they say they do and are much more robust. There's no reason you shouldn't get 5m/min out of these drivers with that screw. Your motors are very poor though a nema23 in parallel should have an inductance of around |<3.2mH ±20% (parallel). Personally if i was going to buy new motors id be looking at 3.1nm or 4nm ones. This wantai driver will run all of those fine:Cnc 4.2A,50VDC,128Micro Bipolar CNC digital Wantai Nema23 Stepper driver DQ542MA | eBay
    Or if you have a slightly higher budget go for the cw5045's @ £35 ea which have a basic level of dsp in them or cwd556's full dsp drivers @ £45 ea (i have two of these with 3.1nm 23's moving a 200kg gantry at 5m/min, probably go faster but i have gearing in not completely satisfied with). All these drivers come from the same company in Jiangsu, wantai just rebranded the cheaper ones but not the cw5045 which often get mistaken as the same, the cw5045 has twice as many components in (i took both apart and checked lol). I have one
    machine running these and another with the
    cwd556 dspdrivers and the more powewrful cwd872 for over 3 years and they havent missed a beat.
    Quote Originally Posted by DDMODS View Post
    I think the motor's inductance is too high. Probably you salvaged it from a working machine?
    I would suggest that you find another motor around 3mH to 6mH if you want to use 24v-48v. The recommended working voltage for 17mH motor is 130V if you want high speed & good torque.
    Besides, high inductance motor can fry your 24v driver easily
    Aug 2015
    45
    Quote Originally Posted by foreveryoung View Post
    It was just the motors I had on my last machine.
    I will get some new motors and maybe drivers after a few jobs and upgrade them and see how it goes. Cheers thanks for the help!!
    Jun 2014
    777
    Personally I wouldn't go for any over 3.5mh. Especially with the tb drivers. Over 4 and your back into the cheap and nastys.
    May 2005
    1397
    Tb6560... there's the problem right there.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Aug 2016
    5
    109jb,
    Do you mind sharing what motors you have that run 180IPM? I am assuming they are nema 23?
    Thx.
  1. Replies: 61
    Last Post: 04-30-2023, 10:12 AM
  2. Testing Nema 23 versus 34 stepper - odd findings (to me)
    By kochevnik in forum Stepper Motors / Drives
    Last Post: 11-22-2015, 03:22 PM
  3. Need help inthe difference in Nema 17 motors
    By mikey4646 in forum Stepper Motors / Drives
    Last Post: 11-22-2014, 01:39 PM
  4. G02, G03 and Radius versus I,J difference?
    By dynamo15 in forum G-Code Programing
    Last Post: 09-07-2013, 09:34 AM
  5. Difference in Kernel Speeds?
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 04-28-2007, 10:24 PM
