603,546 active members*
3,949 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Post edit help?
Results 1 to 13 of 13
    Apr 2006
    11
    Post edit help?
    Just started a new job. First time with Surfcam. 2003
    Now where is the Pst file that I have to edit, because the "Old man" wants circle done in simple two lines, so the program will be short, easy to transfer, cuz we dont have and DNC setup to transfer, still doing old fashion way.
    I Guess I have to change ByQuad value to "N". But where is that file??
    Surfcam is a bit straight forward, doent let you do a lot of things, or maybe I havent gone that far (its 4 days I am using it).
    Oh Yeah! How do I disable "infinite look ahead" in Surf?
    Anyway first thing is to know how do I get to the pst file, open it in what?
    There are tons of pst file in Mpost? folder, and I have to edit fanuc pst. In one directory there are 3 exe files one for wire, mill and lathe, and when I post the program, one of these files execute and ask me bunch questions like for which machine? program number? and work offset.
    If anyone can help me, plz reply. I am on a weeks trail and its going to be over. And employers dont like new guys doning mistakes and look clueless. Though its ok for someone who's been working there for long time.
    Dec 2004
    11
    The Surfcam.pst file is a file that Surfcam uses to direct the file your posting to the post. The actual post that your wanting to change is called postform.m and it is located in the PostLib folder. But as always make a backup copy before changing, an inadvertent change to either of these files can be a real headache.
    Aug 2005
    249
    You need to open the PostForm.m file and find the post file name that you intend to edit. Depending on the number of posts you have added to SurfCAM there could be alot. I found that the newest posts are loaded at the end of the PostForm.m file. Look for the titles "name [the post name that appears in SurfCAM]". These are basically the same as the files in the POSTLIB, MPOST folder. You have to change the PostFrom.m file as SurfCAM does not even look at the .M3 files.
    I made a backup of the PostForm.m file and then deleted all the posts that we do not regularly use from the PostForm.m file. This makes it alot easier to edit the posts when you need to.
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
    Apr 2006
    11
    Thanks guys, it really helped me. Found that post file and edit that, most of the thing is as I want except one thing.
    1stToolChange # First tool change
    G0 x0.0 y0.0
    T[Tool] M6 (0 e[ToolDiam] f[corner]
    Comments
    G0 X[H] Y[V] # "G90 G[Work]" Taken out
    G43 H[Lcomp] Z[D] M03 M08 S[Speed]
    End
    In here I am getting tool dia and corner rad in this format.
    ( Tool dia: 1 C Rad: .2
    But it is missin a ) to close it
    In The bigening of Post processor I have ( 00
    But there is no entry about )
    I put a line ) 00 and edit that line to T[Tool] M6 (0 e[ToolDiam] f[corner])
    but it didnt work got error, any idea how can I get a ) to close it?
    Aug 2005
    249
    We should know what the controller is you are trying to fix. Some controllers don't need closed comment lines.
    Jeff Lange
    Apr 2006
    11
    They are fanuc, haas and fadal. As I have been told by the superviser, he want them to be closed, even if the controller dont need it.
    Any suggestion what is suppose to be fixed in it?
    I am posting the post file here, it has all my edit too that I did yesterday.
    name FANUC
    % 00
    ! 00
    / 00
    O >4
    N >4
    G 2
    X ->3.>4
    x 1.1 X
    Y ->3.>4
    y 1.1 Y
    Z ->3.>4
    z 1.1 Z
    A ->3.>4
    I ->3.>4
    J ->3.>4
    K ->3.>4
    Q ->3.>4
    R ->3.>4
    P >40
    F >3.1
    H >2
    D >2
    T >2
    S >4
    M >2
    ( 00
    d >3.>4
    e >3.>4
    f >3.>4
    SbackDoor SupressHeader
    ModalLetters X Y Z F R # List of letters that are modal (Added R in modal -26/1/2007-)
    ModalGs 0 1 73 74 76 80 81 82 83 84 85 # List of g codes that are modal
    Sequence#s N 1 1 1 # Char, freq, incr & start
    First#? N # Y or N 'Output 1st sequence no.
    Last#? N # Y or N 'Output last sequence no.
    HCode X # X or X U 'Horizontal char.
    VCode Y # Y or Y V 'Vertical char.
    Dcode Z # Depth char.
    FeedCode F # Feed rate char.
    Comment ( ) # Begin End comment char.
    Spindle 3 4 5 # Cw, ccw & stop m codes
    Coolant 8 9 7 61 62 63 64 # Flood, Off, Mist and Thru Spindle M codes
    DComp 41 42 40 # Left, Right & Cancel m codes
    LComp 43 49 # On & Off codes
    Feed G01 # Linear move
    Rapid G00 # Rapid positioning word
    ArcPlane G 17 18 19 # G19, G18, G17 Arc Plane selection
    ReturnPlane 98 99 # G98 G99 Return Plane selection
    Cw G2 # Circular move clockwise
    Ccw G3 # Circular move counter clockwise
    Inc/Abs G 91 90 #Inc& Abs char. & values
    CtrCode R # I J or R or I J K L
    Helical? Y
    Spaces? Y # Y or N 'Spaces between words
    Incremental? Y # Y or N 'Inc or abs output
    CtrIncremental? Y # Y or N 'Inc or abs I & J
    ByQuadrants? N # Y or N 'Break arcs at quadrants (changed from 'Y' to'N")
    UppercaseComments? Y # Y or N 'Require uppercase comments
    Drill # Drilling canned/manual cycle
    G81 Z[D] R[Vclear] F[FRate]
    end cancel
    # (Line "G[RetPlane] X[H] Y[V]" Taken out
    # (From all Canned Cycles -26/1/2007-)
    CSink
    G82 Z[D] R[Vclear] F[FRate] P[Dwell]
    end cancel
    Peck # Pecking canned/manual cycle
    G83 Z[D] Q[VBite] R[Vclear] F[FRate]
    end cancel
    Tap # Tapping canned/manual cycle
    if [Rigid] > 0
    G93 G93 to lock Z to spindle rotation.
    G84 Z[D] P[Dwell] R[VClear] F[FRate]
    else
    G84 Z[D] R[Vclear] F[FRate]
    Endif
    end cancel
    LTap # Left handed tapping cycle
    G74 Z[D] R[Vclear] F[FRate] Q[VBite]
    end cancel
    Ream # Reaming canned/manual cycle
    G85 Z[D] R[Vclear] F[FRate]
    end cancel
    Bore # Boring canned/manual cycle
    G86 Z[D] R[Vclear] F[FRate]
    end cancel
    Back # Back boring canned/manual cycle
    G87 Z[D] R[Vclear] F[FRate]
    end cancel
    Cancel # Cancel a canned/manual cycle
    G80
    if [Rigid] > 0
    G94 Unlock Z if w/ rigid tap.
    endif
    End
    StartCode # Start of the program
    %0
    !0 O[Program#]
    G17 G20 G40 G49 G54 G80 G90 G98
    End
    G0 x0.0 y0.0
    Comments
    End
    Infeed # Enable cutter comp
    G[Side] X[H] Y[V] D[DComp] F[FRate]
    end
    Outfeed # Disable cutter comp
    G1 G40 X[H] Y[V]
    end
    ToolChange # Secondary tool changes
    M9
    G28 G49 Z0.0 M19
    M1
    Comments
    G0 X[H] Y[V] # ("G0 G[Work] X[H] Y[V]" Taken Out -26/1/2007-)
    G43 Z[D] H[Lcomp] M03 M08 S[Speed]
    End
    EndCode # End of the program
    M9
    G28 G49 Z0.0 M19
    G28 Y0.0
    M30
    %0
    End
    replace "d" with "Rad: " # (Brought down to short name -26/1/2007-)
    replace "e" with "T DIA: "
    replace "f" with "C RAD:"
    Dec 2004
    11
    You need the ) 00 after the ( 00
    Then try changing this line
    to this
    T[Tool] M6 (0 e[ToolDiam] f[corner] )0
    Apr 2006
    11
    I think I did that but did'nt write the line )0 instead just ).
    And shorten it to just ) 0 in the first part of post this way I had to just write (T[Tool] M6 (0 e[ToolDiam] f[corner]) without 0 after it. Will try exctly as you saying and see the result.
    Thanks for the help, really appreciated.
    Apr 2006
    11
    Quote Originally Posted by JimW View Post
    to this
    Now the result I got was ( ) Tool Dia: 1 Rad: 0
    Any idea why?
    What is the language these Posts are written in? Any web site link? so I can learn, I have done Oracle in the past so I know the concept.
    Apr 2006
    11
    Thanks a lot guys for help. Lost my job anyway. The boss was looking for some kind of his right hand and I am not close to his pinki. I know I am not stupid or geek, but it gets tough when I have to work with ppl stuck in 80's and use DOS virsion cnc software.
    I solved the issues they had with surfcam, in the mean time I was editing the NC files in note pad (like everyone there), and now the programs are posting flawless, ready to run on machine. Maybe my job is done fixing the bugs they had which I dont think was a big deal.
    Now I am back to looking for job..
    Sep 2009
    Problems with post.ini and surfcame.pst
    I'm sure this should be a new thread but, I'll darned if I cant find the link to start one....
    I have two post templates fanuc dam 0t.L and fanuc dam 10t.L
    This is how it looks in the post.ini file:
    [LPOST]
    Format C:\SURFCAM\POSTLIB\fanuc dam 0t.L
    AutoOpen? Yes
    Format C:\SURFCAM\POSTLIB\fanuc dam 10t.L
    AutoOpen? Yes
    When I open the NC Operations manager the two templates are listed. But only the second template is selected regardless of which I select in the Operations manager... its got to just be a matter of syntax. Can anyone point out my error(s)?... Thank you for the help.
    Here is the lathe section of surfcam.pst.
    BeginPost Lathe Default:1
    PostItem Fanuc D.A.M. 0T
    Status Fanuc D.A.M. 0T
    ChDir "C:\SURFCAM\Velocity3\MPOST"
    Delete "%p%N.TAP"
    Command "C:\SURFCAM\Velocity3\MPOST\LPOSTWIN" "%p%N"
    PostItem Fanuc D.A.M. 10T
    Status Fanuc D.A.M. 10T
    Delete "%p%N.TAP"
    EndPost
    Oh, I am using PostHaste.
    Thanks again
    Mar 2005
    10
    post items
    Cadguy7,
    Try changing this line in the first item:
    to:
    Command "C:\SURFCAM\Velocity3\MPOST\LPOSTWIN" "%p%N" 01
    and the same line in the second item to:
    Command "C:\SURFCAM\Velocity3\MPOST\LPOSTWIN" "%p%N" 02
    good luck,
    nick.
    P.S. I forgot to say, the 01 and 02 should reflect the position of each post in the postform.l file.
    Sep 2009
    Nick Reese IS THE MAN!
    Thanks so much for the fast and right answer..
    Best of luck,
    CADGUY7
  1. Need to edit Haas post
    By Shotout in forum Post Processors for MC
    Last Post: 12-07-2007, 06:35 PM
  2. Edit/Modify MC Post, Then Verify???
    By Dugg in forum Mastercam
    Last Post: 12-30-2006, 02:16 PM
  3. Edit Haas VF Post
    By trangt143 in forum Post Processors for MC
    Last Post: 11-22-2005, 03:55 PM
