586,070 active members*
3,518 visitors online*
    Jul 2016
    Question Looking for opinion on this 60W laser cutting machine
    Hello,
    I've been lurking around the forums recently, because I'm interested in purchasing a laser cutting machine.
    This is the machine I've found that seems to fit the needs: 60W CO2 USB LASER ENGRAVING CUTTING MACHINE ENGRAVER CUTTER WOODWORKING/CRAFTS | eBay
    I will mostly be cutting cardboard and different types of paper. I assume the 60W laser is too powerful for this job, but I need the larger surface area and this is the compromise I have to make.
    What do you guys think of this machine? Is it decent quality?
    Nov 2015
    371
    Re: Looking for opinion on this 60W laser cutting machine
    Can you give a little more information on the projects you have in mind? What are you intend to cut from cardboard? How precise it has to be? How clear the edges have to be?
    Jun 2014
    611
    the edge of power or cardboard has a little dirty when using laser cutter to cut it, do you know that?
    Try to ask them make samples or send a video to you before you make this order.
    Jun 2016
    22
    I got a better option different type machine kindly contact [email protected]
    wklaserliu Guest
    Quote Originally Posted by Dan21st View Post
    Hello,
    HI Dan,
    we have one model with 60w ,strom600(600*400mm) 60w ,price :1300$
    Attachment 328918
    for more news conatct me : [email protected]
    skype:wkquiven
    whatsApp:8615698041856
  1. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  2. best choice steel sheet cutting machine fiber 500w laser cutting machine
    Last Post: 07-22-2015, 08:46 AM
  3. Need your help & opinion about laser machine
    By hjacksonv in forum Want To Buy...Need help!
    Last Post: 11-27-2013, 09:04 AM
  4. Replies: 0
    Last Post: 05-17-2012, 02:29 AM
