I just solved a problem that has been plaguing me for nearly 2 years so I thought I would share!
My 6090 router from Jinan iTech has been slowly losing position in all axes, especially on complex jobs. This is most obvious in circles and arcs being non-concentric, and the Z height slowly dropping when doing engraving work.
The solution was to set a jumper in each of the M542 stepper drivers to change the pulse logic to negative. The jumper is marked 'J1' and is in a little bank of 6 header pins, visible only by unplugging the driver then removing the plastic cover.
Now it is fixed, I am pretty impressed by the accuracy and versatility of the machine - from ripping up slabs of plywood to engraving tiny details on PCBs.
Background -
The machine runs on a Weihong NK105G3 DSP, with 3 x Leadshine M542 stepper drivers. I use mainly ArtCam and also Eagle plus PCB-Gcode.
I first noticed this effect particularly when using 'area clear' toolpaths on holes.
I managed to contain the problem by switching to a finer micro-stepping resolution and avoiding area clear toolpaths, good enough for most work.
But - I have been running some fine PCB work recently and accumulated errors of near 1mm were terminal!
The error was repeatable - each time I ran the same job I would get the same result - but otherwise confounding as there was no obvious skipping, backlash or other failures I could see.
Returning the machine to relative zero, would end up in a different position to where it started, even though the readout showed 0.000, 0.000.
The technical bit -
The DSP controls the stepper drivers through 2 pairs of control wires sending 'step' and 'direction'.
There are a few different schemes but one variation is 'pulse logic' which can be positive, meaning that each step occurs as the voltage rises from 0 to 5V; or negative, meaning each step occurs as the voltage falls from 5V to 0.
If you look in the NK105 manual on page 83 there is a diagram showing this - the section relates to a servo driver but this is a clue as to what the NK105 is outputting (note the manual says to choose # 2, single pulse stream negative logic).
The M542s on the other hand are set to positive logic by default, at least mine came that way. Page 3 of the M542 manual sets this out.
The repercussion of this is that every time there is a direction change, one micro-step gets counted in the wrong direction. On a complex job, this adds up to a visible error.
Those area clears involved lots of little concentric circles and therefore lots of direction changes!
