586,655 active members*
3,792 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > SprutCAM Videos
Page 1 of 2 12
Results 1 to 20 of 35
    Apr 2016
    44
    SprutCAM Videos
    All,
    Please take the time and visit my new Youtube channel where I will be putting tutorial videos out as frequently as I can. Feel free to like, comment and subscribe on them all as you see fit. If you have any suggestions or are looking for a way to do something, please feel free to email me at [email protected]. I would be happy to shoot a video if it helps you out. Also, any models you think could be used to show a strategy is greatly appreciated as CAD takes longer than CAM for me.
    Hope everyone had a safe 4th!
    https://www.youtube.com/channel/UCo6...JXfElnUbRxaaLQ
    Jun 2006
    3063
    Re: SprutCAM Videos
    Looks like a great start to a useful channel. I made a suggestion for another video, or series of them, and offered to supply a model. If you are interested, what CAD format do you prefer? I can do GeoMagic Design or one of the CAD neutral formats like STEP or IGES.
    Nov 2007
    2151
    Re: SprutCAM Videos
    I was #2 subscriber
    Program is so complex You can make videos about ways to set and usc coordinate systems for the next year and a half alone! I only use a tormach mill with 4th axis and find countless ways to do things and countless combinations of strategies with countless settings that may or may not even generate code my mill uses Then you have lathe ......................work and all those settings!! Your going to be busy! I looked at doing this a year or so ago and figured I would spend to much time in video edit mode and not enough using the cam and tools . Anyway I will be following along!
    About done with this project with 30 igs, sprut and tap files to make every part and only have to clean and assemble
    Attachment 326130
    Fun software to use and worth learning!
    Apr 2016
    44
    Quote Originally Posted by MichaelHenry View Post
    I prefer IGS or STEP. Anything will do though.
    Jun 2006
    3063
    Re: SprutCAM Videos
    Quote Originally Posted by Phillyb24 View Post
    I sent you a PM - Mike
    Apr 2016
    44
    Re: SprutCAM Videos
    Here is the latest, How to Single Form Thread Mill.
    https://www.youtube.com/watch?v=xqHD...ature=youtu.be
    Apr 2016
    44
    Re: SprutCAM Videos
    Another workpiece video. I'm going to try to pump out as many basic videos as I can while working out the more advanced stuff. Keep the requests coming.
    https://www.youtube.com/watch?v=CcwjTCTHpJM
    Nov 2007
    2151
    Re: SprutCAM Videos
    Well done, Very clear and to the point! I remember the first time I defined a single point thread mill it took me an hour and crashed version 8 like 3 times
    You did it so fast I had to watch that 3 times to see if there was any thing I missed!
    Mostly learning 4th axis setups and tool path strategies right now and would enjoy any video of those concepts. So many ways to get results and always looking for new and different methods. Hard for me to use that program without learning something new!
    Thanks again!
    Jun 2006
    3063
    Re: SprutCAM Videos
    Quote Originally Posted by mountaindew View Post
    +1!
    Mar 2015
    164
    Re: SprutCAM Videos
    Phillyb24 your video technique is the best... please keep em coming.
    -uman
    Apr 2016
    44
    Re: SprutCAM Videos
    Thank you all, I am trying to put one up daily, it might be every 2-3 but keep checking! I also have made a facebook page that I will upload new ones to as well for you to have delivered to your feed and to share to your machining friends.
    https://www.facebook.com/sprutcamvideos/
    Jun 2006
    3063
    Re: SprutCAM Videos
    How about a video that describes why those red check marks get generated for some operations even though the tool never crashes into the part. Bonus points for showing us how to get rid of those check marks.
    Apr 2016
    44
    Re: SprutCAM Videos
    Would have to see an example. I never have issues with that as it's usually a setting somewhere. The only time I ever encounter them is when I'm purposely gouging the model (over drilling, thread milling/tapping, etc...)
    Jun 2006
    3063
    Re: SprutCAM Videos
    I run into this on almost every job. On the most recent it was because the model was imported to a location inside the mill table (Tormach, in this case). I usually just ignore the red checks if the part seems to simulate OK, but sooner or later it is going to bite me in the butt.
    One of the things I'd like to see is a series of videos on what each of the parameters in the setup screen do.
    Apr 2016
    44
    Go to Tormach website. The machine definition was updated in April I think to raise it out of the table by default. I can do a video for the setup tab no problem. Another thing I do is always turn off the Pan on the machine definition. Something in 10 doesn't like it.
    Nov 2007
    2151
    Re: SprutCAM Videos
    I find as mentioned here there is some sort of conflicting setting and I always keep reviewing settings and changes or delete and start over with new operations until the problem is fixed. From what I see some of the safe plane and transition options and settings have some sort of hidden error in the data or input field. One error I see all the time is the tool number and length corrector can show correct setting in tool window but have different numbers showing on lower left tool data tab.
    They still have not fixed that? wow I run into this 10 seconds after update. Mentioned it to tormach and they sent me video on how to not locate part in mill table. little giggle because I never had that problem from day one when I started learning this program couple years ago and I use full fixtures, machine is visible for all parts on all operations on all offsets on all sides right down to works stops and tool holders. I try to use the cam tool to its fullest and I can say it has saved me with less tool damage and I don't ever mill AIR
    I have avoided online updates as they have caused me problems in the past and still run only the oem disk release. Wish I could keep updated with out fear of major problems or new and different errors or quirks to work around.
    edit : might be brave someday
    Jun 2006
    3063
    Re: SprutCAM Videos
    Thanks - I just found those definitions and will install them later today
    Is Pan turned off in Machine Setup | Pan Surround | Visible?
    Some videos on Machine Setup parameters would also be appreciated.
    Apr 2016
    44
    Re: SprutCAM Videos
    Yes, although I just click the little arrow icon next to Machine Visibility at the top and then under machine nodes I just click the Pan so it unchecks. I can do a video for that as well. Tormach had it fixed but the most recent update is causing an error at times with the Pan again. I've already notified them it's being taken care of it. Just a quick question on your previous request, when you say Setup do you mean the setup tab that's located next to Job Assignment?
    Jun 2006
    3063
    Re: SprutCAM Videos
    I meant these 2 screens in SC10. Sorry, I may have messed up the names.
    Apr 2016
    44
    Re: SprutCAM Videos
    Sure thing, I can do those right up. Probably tomorrow.
Page 1 of 2 12
  1. Transition from no Sprutcam to Sprutcam-9
    By Uman in forum SprutCAM
    Last Post: 06-09-2015, 12:58 PM
  2. # new Beginning tutorial videos for SprutCAM 7
    By Eric_Tormach in forum SprutCAM
    Last Post: 10-16-2011, 07:31 PM
  3. Help videos
    By Joe Miranda in forum Milltronics
    Last Post: 10-10-2008, 06:11 PM
  4. Videos
    By manuelc149 in forum Mastercam
    Last Post: 11-16-2007, 08:25 PM
  5. Cnc Videos
    By LVJ in forum Spanish
    Last Post: 05-06-2007, 01:25 PM
