586,119 active members*
3,439 visitors online*
Results 1 to 12 of 12
    Nov 2006
    18
    Axle Bushing Needed
    I need one axle bushing made.It's a bushing to convert a Suzuki DR650 axle and make it compatible with Suzuki RMZ 450 shocks. I believe it should be made out of Stainless.
    Mar 2008
    24
    Re: Axle Bushing Needed
    what is the major overall diameter? and where are you located basically?
    Nov 2006
    18
    I am in Virginia. The overall diameter is 1.180" and overall length is 1.669"
    The critical dimensions are the shaft at .980" and the internal bore and threads.
    Dec 2008
    29
    Axle Bushing Needed
    I can make one for you no problem please keep in mind that stainless steel although rust resistant is surprisingly not wear resistant. If it is subjected to friction it will wear. I refer to. 980
    diameter section which looks like it will be sleeved in the wheel hub or frame. If it is fixed somehow and there is no movement than fine otherwise if it rotates freely it can demage the wheel hub or seize without lubrication
    A common practice is to use self lubricating materials like oilite bronze. But this combination is preferred in mating with steel. If you are inserting it into some aluminum alloy part, galvanic corrosion may accrue. Just a thought to consider.
    Mar 2008
    24
    Quote Originally Posted by brfgmike View Post
    diameter section which looks like it will be sleeved in the wheel hub. If it is fixed somehow and there is no movement than fine otherwise if it rotates freely it can demage the wheel hub or seize without lubrication
    A common practice is to use self lubricating materials like oilite bronze. Just a thought to consider.
    Actually stainless is a LOT more wear resistant than any steel! I have done research on that and fixed a guys backhoe dipper bucket, reinforcing the edges with steel, stainless, and AR500, (at his request) and he brought it back wanting stainless to replace the other parts of the wear edges, because it held up so much better, and he digs a lot, whcih dirt wears on that eqwuipment bad.
    Dec 2008
    29
    Axle Bushing Needed
    Lanemfg
    I appreciate your input.
    Backhoe pins do not rotate very fast. Here is a link to some studies if you care to know some more.
    https://www.nickelinstitute.org/~/Me...teel_9006_.pdf
    Mar 2008
    24
    not pins dude, if you read my post, I was talking about the bucket, not pins.
    Nov 2006
    18
    This piece will not have any friction from movement. The axle shaft screws into the sleeve and the sleeve gets clamped into place so there is no movement on this piece.
    Aug 2016
    I could whip that out for you in 316 Stainless very competitively as I have the material and metric tap on hand. My specialty is one-off manual lathe work and I have thousands of hours of experience over the last 30 plus years. Fit and precision guaranteed! PM me if you haven't accepted another quote yet. One week turn around!
    Nov 2006
    18
    This order has been filled. Thank you everyone.
    Hey there, feel like making another one? I'm working on the same project!
  1. Two bushing adapters needed.
    By topduck in forum North America RFQ's
    Last Post: 09-27-2015, 02:19 AM
  2. Replies: 8
    Last Post: 08-21-2015, 07:43 AM
  3. Stainless axle
    By keithmcelhinney in forum North America RFQ's
    Last Post: 10-20-2014, 03:15 PM
  4. Replies: 1
    Last Post: 01-31-2011, 11:29 PM
  5. Is it possible to turn closed round bushing into C shaped bushing ?
    By vroemm in forum Linear and Rotary Motion
    Last Post: 06-27-2006, 11:04 PM
