586,655 active members*
3,558 visitors online*
Thread: Threading
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Jun 2015
    4155
    Re: Threading
    Quote Originally Posted by broby View Post
    just goes to show how little you know at times...
    my god, OSP5000 ? that's huge man !
    Quote Originally Posted by Jmooresshop View Post
    I don't know how to G Code anymore. I'm trying to thread a 5/8-18 thread on CRS by 12 inches length of thread.
    hello mr Jmooresshop ... G codes for 2 methods :
    .... flank compound infeed @ 2.5 degress ( OSUB1 )
    .... zig zag @ 55 degress ( OSUB2 )
    i discovered today that i do have documentation for UN threads
    for this UNF 5/8 was also specified a 1:43 angle [ degrees : minutes ]; i don't know what this means ... anybody ?
    more precise, i found this :
    ... unc 5/8 - 2:56
    ... unf 5/8 - 1:43
    ... unef 5/8 - 1:16
    this code is for a straight thread
    it covers most machining aspects of a thread; also, it goes where & how you wish
    i did not put specific data into it, so it should require x_offset corrections
    well, all cnc's require offset corrections ... this story is for another time
    Code:
    OS00
    ( cnc unit : millimeters                         )
    ( insert   : partial profile , r0.06 ap 1.01     )
        V1 = ...            ( n )
        V2 = 25.4/18        ( f )
        V3 = 5/8*25.4       ( external diameter )
        V6 =-12*25.4        ( thread end point  )
        V11= 1.5            ( ...    start ...  )
        V4=0  ( nominal tolerance               )
        V5=0  ( coeficient for V4               )
        V9=0  ( minimal play                    )
        V7=0  ( ap - c for full profile inserts )
        V12=0 ( cutting depth                   )
        V3=V3-V9-V4*V5+2*V7 ( reference diameter )
      ( IF [ VRSTT NE 0 ] NEND )
      ( M867 )
        G00 X375-VETFX Z-VETFZ
        T060606 ( M66 )
        G00 X+V3+5 Z+V11 ( M63 )
        G97 S=V1 M42 M03 M08
        CALL OSUB1      ( flank compound infeed @ 2.5 degress )
      ( CALL OSUB2 )    ( zig zag               @ 55  degress )
        G00 X375-VETFX Z-VETFZ ( M203 )
      ( NEND )
    RTS
    OSUB1
        CALL OQ00 V10=0.520  V8=0
        CALL OQ00 V10=0.417  V8=20
        CALL OQ00 V10=0.323  V8=18
        CALL OQ00 V10=0.240  V8=16
        CALL OQ00 V10=0.167  V8=14
        CALL OQ00 V10=0.104  V8=12
        CALL OQ00 V10=0.063  V8=8
        CALL OQ00 V10=0.021  V8=8
        CALL OQ00 V10=0      V8=5
    RTS
    OSUB2
        CALL OQ00 V10=-0.057 V8=0
        CALL OQ00 V10=+0.047 V8=20
        CALL OQ00 V10=-0.047 V8=18
        CALL OQ00 V10=+0.036 V8=16
        CALL OQ00 V10=-0.036 V8=14
        CALL OQ00 V10=+0.026 V8=12
        CALL OQ00 V10=-0.016 V8=8
        CALL OQ00 V10=+0.026 V8=8
    RTS
    OQ00
        V12=V12+V8/100
        G00 X+V3+5        Z+V11+V10
        G33 X+V3-2*V12    Z+V6      F=V2 G95
    RTS
  2. #22
    Jun 2015
    4155
    Re: Threading
    Controllers of the OSP5000 series did not come with electronic manuals. Whilst they might be now available (usually for a steep price as well) I do not have them for that controller. Also, it should be noted that the basic programming methods for current controllers are very little changed from the 5000 series, so I suppose I could have extracted the relevant sheets that way.
    cnc+programing does not bring something new ... it just allows for consacrated metal cutting operations to be delivered faster and more reliable
    so, why not consider a wood lathe powered by water, and carve instrunctions into stone plates ?
    i was just trying to be nice broby, i offered to give you my manuals ... how would i know about osp5000 ?
    If an answer can be give by scanning in and posting then why not? Better than not being helpful.
    the issues in this thread won't be solved by G codes ... i wrote them because mr. Jmooresshop asked for it, but also i wrote all those stability details, that are more important
    the best answer in this thread was from kevin0296 ... all other replies are just " exchange of experience "
  3. #23
    Jun 2015
    4155
    Re: Threading
    hello
    .... to drastically reduce cutting force, consider image 1; normally, this is not recomended, because will accelerate tool wear, but since your inserts don't last long, maybe will work for you
    .... to eliminate buckling, consider :
    ........ image 2 : a support pipe, tighten between tailstock and chuck; this solution requires thrust from your tailstock, so more trust is needed, to achieve same pushing force for the live center; your part does not require a lot of thrust, so there should be enough left to tighten that pipe; 1st you push the tailtock, and after you tigten the pipe; at the other end, it stays on a bearing
    ........ image 3 : a suport frame, solidary with tailstock chassis, or how is it called; is simpler, but requires tailstock chassis modification ... kindly !
  4. #24
    Jan 2009
    55
    Re: Threading
    On my mid 1990's Cadet...for an 18 TPI , I wold use F=1 and J=18
  5. #25
    Apr 2009
    1262
    Re: Threading
    Yes that is correct.
    Experience is what you get just after you needed it.
  6. #26
    Apr 2006
    822
    Re: Threading
    Quote Originally Posted by OkumaWiz View Post
    But only on a machine configured in Imperial mode.
    On Metric machines the equivalent is F25.4 J18
  7. #27
    Apr 2009
    1262
    Re: Threading
    OK Aussie, that is right in the land down under...but he did say TPI as in Thread per Inch. ;-)
  8. #28
    Apr 2006
    822
    Re: Threading
    ha ha, well... if you were programming on a metric machine and you used F1 J18 then you would get a mighty fine thread
    Just thought I would point out that there is a difference between measurement systems.
  9. #29
    Jun 2015
    4155
    Re: Threading
    nice, again focus on G codes this one saves the day, especially on last pass ( if it gets there )
    Code:
    G00 X~dia Z+clearance
    G71 X+dia Z-20*dia A... B... C... D... :)
  10. #30
    Jun 2015
    4155
    Re: Threading
    threading long stuff without a following steadyrest :
    use the turret to sustain the bar with a reduction sleeve; on Z+ you should have ~30...50 mm bar out, so to begin threading it by hand ( using a thread die ), so to have the thread start ( 1st drawing from bottom )
    if you consider, clamp the tailstock
    continue threading, by feeding the turret and selecting a comfortable rpm
    at this moment, threading tool may be :
    ... in your hands ( 2nd drawing from bottom )
    ... in a special sleeve ( 3rd drawing from bottom )
    this should get you close to the chuck without worries
    you may set up a turning knife in the same way
    use G33, and stop the machine before it reaches max travel
    setup the knife with a comparator
    this requires a minimal play between the bar and the sleeve ( or whatever sustaining element )
    this involves more work than using a thread die, but you may use this setup to rough the thread, and finish with the die
  11. #31
    Jun 2015
    4155
    Re: Threading
    who is this in english ? true tap love ? tap mothership ? tap egg ?
  12. #32
    Apr 2006
    822
    Re: Threading
    Quote Originally Posted by deadlykitten View Post
    It is a thread Die. the one in the picture is for an M20 thread.
    This die is a fixed size, non-adjustable one.
  13. #33
    Jun 2015
    4155
    Re: Threading
    thank you
Page 2 of 2 12
  1. G33 threading
    By adamant in forum G-Code Programing
    Last Post: 04-15-2015, 02:57 PM
  2. TL-1 IPS Threading
    By DavidhCNC in forum Haas Lathes
    Last Post: 03-25-2015, 06:21 PM
  3. THREADING: How to add threading parameters to the Init file?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-22-2015, 06:50 PM
  4. NPT Threading
    By brow318 in forum Tormach Personal CNC Mill
    Last Post: 09-21-2013, 02:28 PM
  5. Threading ?
    By Get lucky in forum G-Code Programing
    Last Post: 01-12-2013, 10:57 AM
