586,058 active members*
4,600 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > NEED HELP! Chinese 60w Laser cutter won´t turn on.
Results 1 to 8 of 8
    Jul 2016
    9
    Post NEED HELP! Chinese 60w Laser cutter won´t turn on.
    Hello everyone, I am a newbie in the forum and in laser cutting as well.
    I recently bought in Amazon a 60w Chinese laser cutting machine with a working area of 500x700mm. It worked properly for the first non continuous 4 hours. Yesterday I was cutting some pieces and after 30min working it suddenly turned off.
    I checked the emergency stop button and it was on the correct position.
    Checked that the power cord was working right.
    Checked all the connections.
    Maybe it is the power supply?
    May it be a fuse?
    How can I test the power supply? Can any of you tell me where are the fuses in this machine so I can check them?
    Here are some pictures taken from Amazon of the same machine I bought.
    I am an architect with little knowledge in electrical issues.
    Thanks in advance for any help you can provide.
    Arqmoe (from Venezuela)
    Nov 2008
    643
    Re: NEED HELP! Chinese 60w Laser cutter won´t turn on.
    Keep in mind that these units have a number of safeguards like door, water flow, water temperature. Maybe the manual would help. Check easy stuff before messing with electronics.
    Jul 2016
    9
    Thanks for the help. The manual didn't help. I checked everything and discovered that the power switch was malfunctioning. Changed it and solved the issue.
    Feb 2017
    4
    Did you ever figure out what happened? I'm in the same situation right now with the exact same machine.
    Aug 2006
    44
    I think there is a problem in the main fuse.
    check the place that you plug the main electric cable to your laser .
    there is a fuse under that connection .
    check that fuse .
    Mahyar
    Jul 2016
    9
    Quote Originally Posted by floridagirl View Post
    Yes. It was the fuse where the power cord connects into the machine. After several trial & errors, I plugged every other thing separately from the machine. changed most of the wires with ones with higher capacity. The water pump, air pump and air extractor are connected in a voltage regulator.
    Hope this helps. Sorry for the bad english.
    Apr 2018
    My machine is having the same problem, first it was the fuse. It was working fine. Then it went off again! I checked the fuse and in was still good. I don't know what it could be or how to check it. does anyone know what it could be? I could use picture too. Need Help! (flame2)
    Hi Angelina,
    The problem with your laser not turning on can only be traced to the power supply/switch panel of your laser. Probably something is cut, spoilt or burnt on it.
    I'd suggest you call in an electrician to help you check and restore and spoilt part.
    However, of you're familiar with electrical troubleshooting, check the power supply/switch panel and see if there's anything cut.
    From my experience, I'll predict that it's probably the switch that melted since you've confirmed it's not the fuse.
    I hope to hear how this works out.
    Thanks.
  1. My chinese laser cutter won't work at all, software doesn't see the cutter
    By Sasa1234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2019, 04:09 AM
  2. 50w chinese laser cutter wont even turn on. SOS
    By juliewillis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2016, 09:40 PM
  3. 60w Red Chinese Laser Cutter
    By WayneAdams in forum Commercial Laser
    Last Post: 06-30-2016, 08:34 AM
  4. 40w Chinese Laser will not turn on, any advice?
    By bazinga in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-26-2015, 10:46 PM
  5. Chinese Laser cutter Fault
    By bluestorm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-24-2014, 03:57 PM
