586,070 active members*
3,543 visitors online*
    Oct 2008
    9
    2010 Screen Set problems
    Just started setting up the 2010 Screen Set and strange things are happening.
    When I click the Start Cycle button the spindle moves to the Park Position and stops. I click the Start Cycle button again and the spindle moves to the Tool Change position and the Z moves down for Z-Zero after it Zeros it moves to the cut position and begins the cut.
    Any help would be appreciated.
    Bill I
    Re: 2010 Screen Set problems
    I would try re-installing Mach3, preferably a clean install? I can't see any way that any of what you're describing should be able to occur, and I've never heard of this before.
    Cycle Start should never move to the Park position unless your g-code start with an M883 code.
  1. Mach3 2010 Screen set
    By ger21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-12-2024, 06:45 AM
  2. 6T-B CRT Screen problems
    By L98FIERO in forum Fanuc
    Last Post: 07-12-2017, 10:26 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. Problems with TNC 155 Heidenhan Screen
    By Jungle Jim in forum Bridgeport / Hardinge Mills
    Last Post: 12-02-2006, 12:21 PM
