Hi.
New cast iron is not yet stable.
If you machine it, it will change shape after a while.
With old cast iron this is not the case.
Thats why sherline makes its routers with old cast iron.
Is this the same for new and old steel ?
Suppose you make somthing very accurate from new steel.
Will the stressesin the new steel reduce after time ?
And will it change the shape of the steel ?
Causing the accurate surfaces to become inaccurate ?
Thanks..
