Originally Posted by
Imperial Sewing
Hi, thanks for the reply. Its a Conquest 42, Serial Number CS664, !988 vintage, OT Fanuc Control.
The Spindle will run fine in Manual or Set up but when I try to run a program it stops at the spindle on command, no error message displays.How can I tell if Brake Sensor is working? Tried to run machine again just now and now have another problem. The Tool Index Plate is out of wack, this has happened a few times, but I generally am able to follow the Maintenance Manual and get it adjusted back. Don't know why it happens, it appears to occur when machine has been sitting idle for a while. Any help you can give me would be great. Thanks.
Phil
