586,069 active members*
3,425 visitors online*
Thread: Ref X
    Oct 2008
    9
    Ref X
    Hi Gerry
    Thanks for your expertise.
    I have one minor issue.
    When I click the Ref X icon it does move to the correct coordinates but the X, Y & Z DROs do not change to 0.000. When I click the Ref X the second time after all moves are made the DROs display 0.000. What do I have set wrong?
    Bill I
    Re: Ref X
    They're not supposed to.
    Ref X means to "Home" the X axis, which moves the machine to the X axis home switch, which then zeros the X axis Machine Coordinates.
    If you have an X axis offset other than zero, than the X axis DRO will not read zero.
    Ref X does nothing with the Y or Z axis, so those DRO's should not show any change.
    If you've modified the macro, then I'd need to see your macro.
