Hi I am trying to verify some information on the deskcnc machine setup for sherline mill & lathe. Bare with me as I have just got into this new hobby and trying to gather all the information necessary so my terminologies maybe a little off and based on only 2 months worth of online reading.
Sherline Mill 5410 Metric
Sherline Lathe 4410 metric
Controller Imsrv SYS 3A 2nd generation board with Globe motors.
These motors are on a reduction pulley setup on 2.8:1, the manual states that for inch the SPS on pitch 1 or 2 or 3 is so and so and so is true for the metric.
What I would like to know is how do I know which lead screw is being used as each one has it's own value in order to determine the correct SPS and how would one calculate the maximum SPS velocity based on the motor being used since I have the specs of the motor. Am sure there is some sort of calculation for this.
If I do a manual count the gear thats on the motor is 17T and 48T on the pulley gear obviously that comes out to 2.8:1 ratio.
I have managed to set the machine and have it working in either G00 or G01 and works perfectly fine by running via MDI or a small Gcode file either one works. I need to actually measure the real result and see if measurements are correct.
Next I would like to know if under the axis should the maximum velocity of the XYZ axis all be set exactly the same or should each one be different if all 3 axis are running the same motor ?
Any help would be appreciated thank you.
