586,055 active members*
4,176 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > YASKAWA SGMGV-05A (450WATT) powered by servodrive YASKAWA SGDV-5R5A (750WATT)
    Jun 2016
    11
    Hello, I am here again.
    Thank you for all of your previous input.
    My next question is:
    Is it any problem to power my 450WATT servo with my 750WATT servo drive?
    The plan is to power this up in my home where I have access to 220V 50hz single-phase electricity.
    Will there be any kind of conflict or trouble to take into consideration?
    Thank you in advance!
    Henrik.
    15362
    Re: YASKAWA SGMGV-05A (450WATT) powered by servodrive YASKAWA SGDV-5R5A (750WATT)
    Quote Originally Posted by graupnerhansen View Post
    Henrik.
    Yes that will work, If the Servo Drive recognizes the Servo motor Encoder, you will also have to make sure the output amps are set to the motor spec's, or you could fry the servo motor, usually though if the Servo Drive recognizes the Servo Motor, it will set the Parameters needed for that motor, this does not always happen so you have to check
    Mactec54
  1. Yaskawa SGMG servo and SGDV servopack
    By Shefron in forum Servo Motors / Drives
    Last Post: 02-23-2016, 10:55 PM
  2. Yaskawa CACR to SGDV upgrade
    By JAKEFREESE in forum Servo Motors / Drives
    Last Post: 02-12-2016, 01:52 AM
  3. Yaskawa SGDV Servo Lock Issue
    By Rickstar in forum Servo Motors / Drives
    Last Post: 05-01-2012, 10:02 PM
  4. yaskawa
    By outctrl in forum Servo Motors / Drives
    Last Post: 09-16-2009, 02:05 AM
  5. yaskawa help please
    By h_2_o in forum Servo Motors / Drives
    Last Post: 11-20-2006, 02:01 AM
