586,100 active members*
2,810 visitors online*
Results 1 to 3 of 3
    Jun 2016
    13
    Lens diameters - Not FL
    Hi all,
    I am trying to find info on why there are different diameters on lenses and when one should consider changing the laser head to hold different diameters. The info I find on google, is about FL but did not find anything about lens diameters. Would anyone share a link or some knowledge?
    Thnx!
    Apr 2004
    65
    Re: Lens diameters - Not FL
    Bigger diameters are more expensive, so you use them only when you need to.
    We needed to on our latest build because the divergence on the beam was a problem at the end of a 3m beam path.
    Jun 2016
    13
    Thank you!
    Στάλθηκε από το SM-G388F μου χρησιμοποιώντας Tapatalk
  1. Replacing current lens with longer focal length lens question
    By JimInWoodstock in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-27-2014, 04:04 AM
  2. DUAL FOCUS LENS (bifocal lens)
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-12-2013, 08:56 AM
  3. Different offsets for different diameters?
    By penjas14 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2009, 12:33 AM
  4. Is there away to drawl Diameters and not radius?
    By Stampede in forum BobCad-Cam
    Last Post: 06-03-2008, 02:04 AM
  5. large diameters
    By sheedy1999 in forum Haas Lathes
    Last Post: 10-01-2007, 12:43 AM
