First of all, I will be doing a lot of my cutting with cheap Chinese triangular inserts. Because the lathe is very small, the inserts are tiny. KMotionCNC comes with a prefab TNMG tool, but it's large, and it's oriented so it points straight toward the work. I need to know if there is a source of WRL tools out there that will provide me with inserts that are more like the one I have, and I also want to know how I would go about changing the insert's radius and orientation. For example, to use a triangular insert as a right-hand tool, you turn it so the left side is parallel to the motion of the cross slide.
