586,108 active members*
3,072 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Convert Radius/Arc's R or L to coordinates I,K
    Jan 2016
    5
    Hello!
    I'm using SolidCam to generate code for my machines (lathe) and i use default post processor in SolidCam "Okumall" and it work perfectly for most stuff. But there is problem with radius, arc's etc, post processor gererate it as "L", is there any way to set up this to get that "L" in "I and K" coordinates.
    Thank you
    Jan 2016
    5
    Re: Convert Radius/Arc's R or L to coordinates I,K
    Anyone?
    Jan 2016
    5
    GPP code:
    "; $Workfile: OKUMALL.GPP $
    ; $Log: S:/CAD_VCS/GPP/OKUMALL.GPV $
    ; Rev 1.1 22 Nov 1992 11:16:54 Rafi
    ; CAD50
    ; okumal
    @init_post
    global string tool_diameter_f tool_number_f
    global LOGICAL save_machine_plane fl
    global integer drilld parm1_usd drill_num
    global numeric drill_lower_zz drill_upper_zz drill_clearance_zz ffeed hh bb
    global numeric fl1 us99 us us1 flag1 xp zp xp1 zp1
    global logical finish_pending
    global string spin_f xend_f
    global numeric m_feed_flag
    ; Non GPPL variables
    num_user_procs = 0
    line_labels = TRUE ; Jump to N...
    ; GPPL variables
    numeric_def_f = '5.3(p)'
    integer_def_f = '5.0(p)'
    gcode_f = '2.0(p)'
    mcode_f = '2.0(p)'
    xpos_f = '5.3(*2p)'
    xend_f = xpos_f
    ypos_f = '5.3(p)'
    zpos_f = '5.3(p)'
    feed_f = '4.3(p)'
    tool_diameter_f = '5.3/1'
    blknum_f = '5.0(p)'
    tool_number_f = 'z2.0(p)'
    blknum_gen = true
    blknum_exist = TRUE
    blknum = 2
    blknum_delta = 2
    blknum_max = 3200000
    gcode_space = TRUE
    spin_f = '5.0(p)'
    ; trace "all":5
    ; trace "@rapid_move,@line,@arc":1
    endp
    @start_of_file
    ; before tools definition
    {nl, ''}
    {nb,' (', g_file_name, ')'}
    flag1 = 0
    endp
    @start_program
    ; after tools definition
    endp
    @end_program
    call @rapid_move
    endp
    @end_of_file
    {nb, 'M02'}
    {nl, '%'}
    endp
    @relative_mode
    ; gcode = 91
    ; {nb, 'G'gcode, ' '}
    ; skipline = FALSE
    endp
    @absolute_mode
    ; gcode = 90
    ; skipline = FALSE
    endp
    @machine_plane
    endp
    @call_proc
    if prev_command eq '@fourth_axis'
    fl = false
    else
    fl = true
    endif
    endp
    @proc
    endp
    @end_proc
    endp
    @loop
    endp
    @end_loop
    endp
    @def_tool
    endp
    @rapid_move
    gcode = 0
    {nb, ['G'gcode]}
    {[' X'xpos] , [' Z'zpos]}
    endp
    @line
    gcode = 1
    {nb, ['G'gcode]}
    {[' X'xpos], [' Z'zpos]}
    if prev_command eq '@turn_proc' then
    change(feed) = TRUE
    endif
    if m_feed_flag eq 1
    {' F'feed}
    m_feed_flag = 0
    else
    {[' F'feed]}
    endif
    if flag1 eq 1
    {' M8'}
    flag1 = 0
    endif
    xp = xpos
    zp = zpos
    endp
    @arc
    xp1 = abs(xp - xpos)
    zp1 = abs(zp - zstart)
    if xp1 gt 0.002 or zp1 gt 0.002
    {nb}
    ;-- arc plane --
    if arc_direction eq CCW then
    gcode = 3
    else ; CW
    gcode = 2
    endif
    {['G'gcode]}
    {[' X'xpos]}
    {[' Z'zstart]}
    if arc_size eq 360 then
    ycenter = -ycenter
    {' I'xcenter_rel, ' J'ycenter_rel}
    else
    if arc_size >= 180 then
    radius = -radius
    endif
    {' L'radius}
    endif
    if m_feed_flag eq 1
    {' F'feed}
    m_feed_flag = 0
    else
    {[' F'feed]}
    endif
    endif
    xp = xpos
    zp = zstart
    endp
    @compensation
    if side eq COMP_LEFT then
    gcode = 41
    endif
    if side eq COMP_RIGHT then
    gcode = 42
    endif
    if side eq COMP_OFF then
    gcode = 40
    endif
    {nb 'G'gcode ' ' }
    if side <> COMP_OFF
    skipline = false
    endif
    endp
    @delay
    gcode = 4
    {nb 'G'gcode, ' P'delay_period:integer_def_f}
    endp
    @change_ref_point
    endp
    @home_number
    endp
    @rotate
    endp
    @fourth_axis
    if fl
    if angle eq 13
    if fl1 <> 13
    gcode = 13
    fl1 = 13
    {nb ' G'gcode}
    endif
    else
    if fl1 <> 14
    gcode = 14
    fl1 = 14
    {nb ' G'gcode}
    endif
    endif
    endif
    endp
    @turn_change_tool
    bb=tool_ALFA
    xpos = xtool
    zpos = ztool
    call @rapid_move
    {nb , 'G50 S',spin_limit}
    {nb ,'T'tool_number tool_number tool_number }
    if spin_unit eq 0 ; Mm/Sec
    {nb ,'G97 '}
    else
    {nb ,'G96 '}
    endif
    skipline = false
    xpos = xnext
    zpos = znext
    gcode = 1
    call @rapid_move
    tool_direction = CCW
    ; mcode = geer
    {' M42'}
    call @start_tool
    fl = true
    flag1 = 1
    endp
    @message
    {nb, '(', message, ')'}
    endp
    @turn_drill
    xpos = 0
    zpos = drill_upper_z+safety
    call @rapid_move
    gcode = 74
    if drill_type eq drilling then
    down_step = drill_depth+safety+1
    endif
    if drill_type eq peck then
    endif
    if first_cut eq 0
    first_cut = down_step
    endif
    {nb 'G'gcode,' X'xpos ' Z'drill_lower_z ' D'down_step ' L'first_cut ' F'feed }
    if delay <> 0
    {' E'delay }
    endif
    endp
    @drill_point
    endp
    @mirror
    endp
    @end_drill
    endp
    @halt_program
    {' M0'}
    endp
    @round_comp
    ; NOP
    endp
    @start_of_job
    message = msg
    endp
    @end_of_job
    bb=0
    endp
    @assign_axis
    ; TBD
    endp
    ; USER DEFINED PROCEDURES
    @start_tool
    if tool_direction eq CW then
    mcode = 4
    else ; CCW
    mcode = 3
    endif
    {' S'spin:integer_def_f, ' M'mcode}
    endp
    @stop_tool
    {' M5'}
    endp
    @turning
    if work_type eq ROUGH then
    gcode = 85
    {nb,' M8'}
    {nb, 'G'gcode, ' NLP'label}
    {' D'(2*down_step) }
    if rough_offset_x ne 0 then
    {' U'rough_offset_x}
    endif
    if rough_offset_z ne 0 then
    {' W'rough_offset_z}
    endif
    {' F'feed }
    endif
    if work_type eq COPY then
    gcode = 86
    {nb,' M8'}
    endif
    endif
    {' F'feed }
    endif
    if semi_finish then
    gcode = 87
    {nb,' M8'}
    if semi_offset_x ne 0 then
    {' U'semi_offset_x}
    endif
    if semi_offset_z ne 0 then
    {' W'semi_offset_z}
    endif
    endif
    if finish then
    gcode = 87
    {nb,' M8'}
    endif
    endp
    @turn_proc
    {nl, 'NLP'label}
    if process_type eq LONG
    gcode = 81
    else
    gcode = 82
    endif
    {' G'gcode}
    endp
    @turn_endproc
    gcode = 80
    {nb, 'G'gcode}
    {nb,' M9'}
    endp
    @end_job_procs
    endp
    @feed_spin
    m_feed_flag = 1
    if feed_unit eq 0
    us99 = 94
    us = us+1
    us1 = 0
    else
    us99 = 95
    us1 = us1+1
    us = 0
    endif
    if us eq 1
    {nb 'G'us99}
    endif
    if us1 eq 1
    {nb 'G'us99}
    endif
    if change(spin) then
    {nb, 'S'spin}
    endif
    endp
    @thread
    local numeric taper_angle
    taper_angle = ang(last_pos_z-first_pos_z, last_pos_x-first_pos_x)
    if taper_angle < 0 then
    taper_angle = taper_angle + 180
    endif
    if is_line then
    if work_type eq multiple then
    if process_type eq long then
    gcode = 71
    else
    gcode = 72
    endif
    hh=depth
    {nb,'G0 X'((last_pos_x*2)+depth+depth+depth)}
    {nb, 'G'gcode, ' X'first_pos_x:xpos_f, ' Z'last_pos_z, ' B'bb}
    {' D'down_step:xpos_f, ' U'last_cut:xpos_f}
    {' H'depth:xpos_f, ' L'chmf_leng}
    if lead_unit eq pitch_inch
    { ' F25.4 J'lead, ' M'm1, ' M'm2, ' M'm3}
    else
    { ' F'lead, ' M'm1, ' M'm2, ' M'm3}
    endif
    else
    gcode = 33
    else
    gcode = 32
    endif
    {nb, 'G'gcode, ' X'first_pos_x:xpos_f, ' Z'last_pos_z, ' F'lead}
    endif
    if taper_angle <> 0 then
    {' A'(180+taper_angle)}
    endif
    endif
    endp
    @groove
    gcode = 73
    {nb, 'G'gcode, ' X'first_pos_x:xpos_f, ' Z'last_pos_z, ' K'side_step}
    {' D'down_step:xpos_f, ' DA'release_dist:xpos_f}
    else
    gcode = 74
    {nb, 'G'gcode, ' X'first_pos_x:xpos_f, ' Z'last_pos_z, ' I'side_step:xpos_f}
    {' D'down_step, ' DA'release_dist}
    endif
    endp
    @turn_opt_parms
    endp"
    i tried to edit this:
    ";-- arc plane --
    gcode = 3
    else ; CW
    gcode = 2
    endif
    {['G'gcode]}
    {[' X'xpos]}
    {[' Z'zstart]}
    ycenter = -ycenter
    else
    radius = -radius
    endif
    {' L'radius}
    endif"
    to this:
    ;-- arc plane --
    gcode = 3
    else ; CW
    gcode = 2
    endif
    {['G'gcode]}
    {[' X'xpos]}
    {[' Z'zstart]}
    if arc_size >= 0.1 then
    ycenter = -ycenter
    {' K'xcenter_rel, ' I'ycenter_rel}
    endif"
    it was close but machine not accept...
    does anyone know solution?
  1. Small radius good Large radius bad
    By K2Developmentab in forum Fadal
    Last Post: 09-26-2013, 07:26 PM
  2. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  3. 021 start radius end radius error
    By XAD in forum Tree
    Last Post: 06-01-2012, 04:59 PM
  4. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  5. Inch,Radius => Metric,Diameter Post Processor Convert !
    By AbuTarif in forum Post Processor Files
    Last Post: 06-21-2011, 05:48 PM
