586,463 active members*
3,384 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > B-Axis Backlash #1851
Results 1 to 2 of 2
    Aug 2006
    131
    The book says it may be adjusted -9999 to 9999. For XYZ these units are in microns. What fraction of a degree is each unit worth for the B-axis for FA630?
    "Teach the ignorant, care for the dumb, punish the stupid."
    Sep 2008
    33
    Re: B-Axis Backlash #1851
    I'll assume you already solved this problem, but, if you didn't....
    The Fanuc manuals claim that the units for Grid Shift (1850), and Backlash (1851) are in microns. Over the 20+ years I've been repairing CNCs, this has rarely been the case. I typically make an adjustment of 25 or 50, record the amount of movement, then calculate how much more I need to adjust from there. With backlash, you can simply put in a number and decide how much to increase without calculating anything, since it's not very exact.
    The rule of thumb when I worked at Yamazen (which I still follow today) was; If you have a value greater than 100 in PRM 1851, it's time to find the mechanical issue.
  1. Z Axis Backlash
    By gleas in forum Novakon
    Last Post: 07-17-2010, 11:18 PM
  2. X axis backlash SX3
    By kenealym in forum Syil Products
    Last Post: 04-28-2010, 03:30 AM
  3. Replies: 0
    Last Post: 06-03-2009, 12:32 AM
  4. Z axis backlash.
    By wyc in forum Syil Products
    Last Post: 09-04-2008, 08:20 PM
  5. Backlash C-axis
    By M-man in forum Daewoo/Doosan
    Last Post: 05-10-2007, 04:40 AM
