586,108 active members*
3,111 visitors online*
    Oct 2006
    how to programmatically pause
    Hi all. I have installed EMC2, I’m building my first cnc and learning gcode programming. I would like to stop (pause) the flow of my gcode programmatically - I mean, the equivalent of pressing the “P” key. I thought that (MSG, change the bit) would work, but it didn’t. The machine doesn’t stop, it goes on instead, without waiting me to click the OK_button of the alert box. Now I’m using this code:
    (MSG, change the bit within 20 seconds or hit P)
    D4 P20
    …which seems a bit stupid to me. Is there another way?
    Dec 2004
    524
    I generally write:
    m0 (msg, change to dovetail cutter at surface)
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Oct 2006
    Thank you Ken, I'm a beginner.
  1. Cycle pause in effect? What?
    By kentavv in forum Mach Software (ArtSoft software)
    Last Post: 09-05-2019, 09:57 PM
  2. Pause under G-Code control
    By gregger2k in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-31-2012, 07:54 PM
  3. How to pause Turbocnc
    By jimglass in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-28-2006, 12:06 AM
  4. VF-4 Tool changer pause!!
    By ZR Machine in forum Haas Mills
    Last Post: 11-02-2005, 01:52 AM
  5. Gcode pause command?
    By mark296 in forum G-Code Programing
    Last Post: 08-14-2005, 02:13 AM
