586,047 active members*
3,614 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion 5 tapping issues
Results 1 to 10 of 10
    Jun 2010
    119
    I have a 1991 Partner 1D mill with a Centurion 5 controller. I've been trying to get it to ridgid tap with no success. I do have the tapping option. I found in other threads that I have to use G88 on this machine for ridgid tapping, although that isn't in the manual, only G84. Any time I use G88 the machine shuts down with an error 200. Using G84 it isn't reversing for some reason. I've tried all kinds of combinations with no luck. There is a G63 code in the book for tapping mode but it isn't in any examples and it doesn't make any difference.
    My code looks like this :
    G84 X-5.2439 Y-.492 Z-.225 R.1 F25. G98 doesn't reverse.
    G84 G63...... Doesn't reverse.
    G88 machine stops.
    G88 G63 stops.
    Any suggestions what could be wrong or if I'm doing something wrong? I come from Fanuc controls.
    Mike
    Sent from my LG-H830 using Tapatalk
    Jun 2010
    119
    Re: Centurion 5 tapping issues
    I just realized that the VFD has been replaced with a SafeTronics GP-10 drive at some point. I'm wondering/guessing that is why it isn't working correctly?
    Oct 2008
    427
    Are you absolutely certain that your machine has the spindle encoder necessary for the rigid tap cycle to work?
    Conversational programming and the G-code list may show the G88 cycle, but not all machines had the encoder installed.
    Look under the covers on the head to check for the encoder which will be belted to the spindle.
    If it is there, make sure that the belt is in position and the pulley is tight. Also check that the MISC parameter Spindle Encoder PPU is set correctly.
    What version is the software in your machine?
    Jun 2010
    119
    It's definitely there. Belt seems ok, but I'll double check it tomorrow and check the parameter.
    1.28.23 is the controller version.
    Nov 2013
    128
    So I think your feed is wrong. When rigid tapping, your feed is relative to spindle rotation. For example, for a 1/4-20 tap, your feed is the pitch, .050". The error is probably because the control knows the machine is not capable of moving at 25" per revolution.
    Quote Originally Posted by EmeraldIsleforg View Post
    G88 machine stops.
    G88 G63 stops.
    Mike
    Jun 2010
    119
    Hi Allen, I tried both feeds to make sure,.025 gives an error that it is out of range.
    Apr 2003
    637
    I use this for 1/4-20 tap:
    O1
    G90G80G40G17
    T1M6
    G0G54X0Y0
    M3S3056
    G43Z1.1H1
    M8
    G88X0Y0Z-0.75R0.1F0.05
    G80
    M5M9
    G32
    G49M2
    Jun 2010
    119
    ZZZZ, you were right! The spindle encoder ppu was at 0.a setting sheet in my manual had it at 2000. I changed it back and it works now! At least in air, going to try metal now.
    Oct 2008
    427
    Good news, congrats
    I would go check all the rest of the parameters as well, if you haven't already done that.
    Dec 2017
    10
    HI there I know this is a really old post, but i have a similar mill with the rigid tap option that used to work fine and now its doing the same thing, i was hoping you could tell me which parameter had the spindle encoders ppu stored in it
  1. Rigid Tapping in 2006 VM2 Issues
    By smcdonn in forum Haas Mills
    Last Post: 12-02-2015, 08:56 PM
  2. V25 Tapping issues
    By missinglink in forum BobCad-Cam
    Last Post: 05-18-2013, 08:31 PM
  3. Rigid tapping issues
    By dizzypistons in forum Fanuc
    Last Post: 03-09-2013, 04:38 AM
  4. Tapping Issues on our V2XT
    By 5S Dude in forum Bridgeport / Hardinge Mills
    Last Post: 05-05-2010, 04:24 AM
  5. rigid tapping issues
    By stebanski in forum Haas Mills
    Last Post: 06-14-2007, 11:56 PM
