586,121 active members*
3,556 visitors online*
    Jan 2004
    539
    ST10 with manual chuck
    So for a particular application I am going to put a manual chuck on the ST10. Now it will alarm if you don't have the chuck closed.
    I have never had the chuck off before so not sure if I can block off the lines so I can "close chuck" to fool the control..or is there a way to disable it through the control?
    Gary
    Oct 2011
    106
    Re: ST10 with manual chuck
    Can you put a manual chuck into the hydraulic chuck?
    Sent from my iPad using Tapatalk
    Jan 2004
    539
    No..but that would solve the problem!
    Gary
    Oct 2008
    1632
    Old thread but just in case this ever comes up again, Yes.
    You can remove your hyd. chuck, unscrew the drawtube if it doesn't clear. I prefer unscrewing it so I don't damage it or get coolant and swarf between the spindle and tube.
    I made a round plug with o-ring to push into the spindle to keep trash out. Bolt up manual chuck and go. Haas recommends keeping the hyd. chuck commanded in the close position so hydraulic pressure will also help keep trash and coolant out of the hyd. system, plus the lathe won't run unless it is.
  1. Anyone using a MANUAL chuck on their CHNC lathe?
    By torinwalker in forum Hardinge Lathes
    Last Post: 04-24-2021, 10:39 PM
  2. POST for HAAS ST10
    By micromouse in forum Dolphin CAD/CAM
    Last Post: 11-25-2014, 12:16 PM
  3. manual chuck on mori lathe
    By SHKROHN in forum Mori Seiki lathes
    Last Post: 09-22-2008, 04:50 PM
  4. manual chuck
    Last Post: 09-09-2008, 08:17 PM
  5. Manual chuck on SL-10?
    By martsto in forum Haas Mills
    Last Post: 08-10-2006, 02:11 AM
