586,114 active members*
3,248 visitors online*
    Jan 2016
    53
    How can I smooth out G01 X,Y points?
    I'm writing gcode to follow a Spline/Curve along a path of X,Y points.
    I notice however, that when I send the gcode to my laser machine, the laser head moves in a jerky fashion vs smoothly.
    Is there some kind of known gcode method to plot along an X,Y path that results in a smooth laser head movement?
    I'm using Grbl 0.9i so I don't have a lot of advanced gcode commands available to use.
    Thanks...
    Apr 2015
    327
    Re: How can I smooth out G01 X,Y points?
    I think that better way is smooth line in a Cam. Do you have this geometry?
    Marek
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Jun 2010
    4256
    On some systems that would mean you are in exact-stop mode: stops after every move.
    What you would want in that case is constant-velocity mode.
    Cheers
    Roger
    Jan 2016
    53
    @RCaffin you're correct...that fixed it...thanks...
    Jun 2010
    4256
    My pleasure.
  1. tb6560 x axis is grinding y is smooth z is smooth im a newbie
    By Hotrod10 in forum Stepper Motors / Drives
    Last Post: 04-16-2015, 05:11 AM
  2. connecting points
    By mikejkd in forum Autodesk
    Last Post: 05-27-2010, 11:50 AM
  3. Points to Surfs
    By JDcam in forum Rhino 3D
    Last Post: 01-26-2009, 06:04 PM
  4. POINTS
    By el gordo in forum Mastercam
    Last Post: 10-05-2008, 04:41 AM
  5. Points on arcs
    By gguidi in forum Autodesk
    Last Post: 07-25-2006, 01:49 PM
