586,069 active members*
3,517 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    Jul 2016
    Exclamation gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    hii all .. so this is my first post here in this forum i hope i can get some help ..
    i do have a gcc c180 laser engraver and i have a problem that the co2 tube keeps firing a very weak beam even when am not pushing the start button or sent any file to the machine .. it starts firing that beam when i just close the door .. any ideas what's going on ?
    May 2020
    Re: gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    I'm having the same problem, did you ever fix it?
    Many thanks
    Quote Originally Posted by badrawy View Post
    May 2020
    I am looking for more information on the GCC cutter/plotters. Wanting to get a semi professional machine. I think the laser cutters are different though. There isn't a huge amount of info about them but they are recommended in posts like this https://www.howtoheatpress.com/cheap...ting-machines/ with minimal actual feedback.
  1. Chinese Laser firing two beams from one tube
    By daveoka in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2019, 06:58 AM
  2. 50w laser has lost power & does not appear to firing correctly, do i need a new tube?
    By Devoreg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2016, 03:17 PM
  3. Rabbit laser 80w, 5 months old, TUBE STOPPED FIRING LAST NIGHT
    By BohlmanCraig in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-07-2016, 04:00 AM
  4. Laser beam runs on the outside of the laser tube!
    By dadde in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-18-2015, 03:19 PM
  5. Laser tube emitting continuous beam
    By jeaves in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-03-2011, 08:02 PM
