7 Amp X 5 Mosfet Array
SLA5046
Just got a small handful of these ICs for FREE
They appear to be an older IC but free parts is free parts.
(I would have gotten more if I knew what they were
at the time I just grabbed some because they looked
interesting with that BIG heat sink die on the back)
Mosfet Array, 5 Mosfets to each package
3 ICs drive 4 five wire unipolar motors,
and 3 Mosfets left over for other things
Drain Current 7 Amps constant with
about 5.5 Volts on the gate
(if I’m reading the spec sheet right)
possible 15 Amps pulsed
Here is a link to the spec sheet I found
http://www.allegromicro.com/skncatlg/array/sla5046.pdf
EDIT:
Looks Like SLA5024 might be a decent complement
if you're running bi-polars, 4 Fets per package
4 Amps constant, 8 Amps pulsed.
http://www.allegromicro.com/skncatlg/array/sla5024.pdf
Just thought I would point this one out to everyone.
Mike_L
When I was younger I thought I knew EVERYTHING,
NOW, the older I get the more I find out I don’t know!
