586,069 active members*
3,690 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Post processor access violation error
Results 1 to 6 of 6
    Jul 2016
    5
    Question Post processor access violation error
    Hello,
    I recently bought a Chinese Quick 6090 CNC router.
    Via Surfcam's post menu ulity I added new post (.mac file) it says that post has been sucessfully added,
    but when I try to post it in operation maneger I get this error:
    Access violation at adress 0044565C. Read of adress 00000000
    Any idea?
    Thanks.
    May 2013
    142
    Re: Post processor access violation error
    Where did you get the post? That extension doesn't look familiar at all.
    Jul 2016
    5
    The post was on a CD. The CD came with the machine.
    Jul 2016
    5
    well since I didn't found a solution for my post processor problem I started using FANUC 15MB post.
    But I have a question: Is it possible, that because of a wrong post processor my machine is not accurate?
    Yesterday I contour some arcs and they were all off by 2mm.
    Btw: What is a usual file extension for post processor?
    May 2013
    142
    For mpost type posts the extension is usually .M3 for 3 axis mills .M4 for 4 axis mills and so on.
    I've never seen a machine manufacturer provide a post for CAM software before. I'd give up on that .mac file and customize a post from an existing one already in Surfcam.
    You didn't happen to be using a 4mm endmill when you noticed that your arcs were off by 2mm were you?
    Feb 2006
    49
    if the post is pretty close you might be able to edit it yourself. the post is called postform.m and depending on the version is located below .. mpost directory. you state that an arc is off be 2mm that's huge and if the machine ran the tool path and nothing else is wrong you might want to look at gain or could the part have moved etc because posted tool path is pretty simple stuff.
  1. Post processor Error
    By djbird3 in forum Dolphin CAD/CAM
    Last Post: 03-16-2015, 05:53 PM
  2. Replies: 7
    Last Post: 11-14-2014, 07:03 PM
  3. Access Violation error in SCkernal
    By scottsss in forum SprutCAM
    Last Post: 09-13-2013, 06:14 AM
  4. SprutCam Access violation
    By oknups in forum SprutCAM
    Last Post: 11-21-2011, 05:47 AM
  5. Techno post processor error
    By Patternboy in forum Mastercam
    Last Post: 04-12-2008, 09:24 PM
