586,047 active members*
3,645 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Any one successful with RGB to LDC monitor swap?
Results 1 to 7 of 7
    Jul 2016
    16
    I have looked for a new CRT and board but they range from $800 to $1200+ Just thought I would ask if anyone did a DIY monitor change to an LCD. I know the Delta 20 old is but she is mine and I am still having fun for now. By the way, what is this used for?
    Oct 2003
    102
    Re: Any one successful with RGB to LDC monitor swap?
    I don't think its possible to do on a Delta 20. To change out the display for an LCD, you'd need a VGA card which wasn't available on the Delta 20 (as far as I know).
    Your picture shows a jog wheel. You turn it to move the axes in jog mode.
    Jan 2009
    52
    You can not just add a board to the CNC. The Delta 10/20 were true CNC with all custom hardware. The 30?40/50/60 and Delta 2000 have a basis on PC hardware and can run VGA monitors without a real issue. As stated you would need a some type of converter to change the signal type to run one of today's monitors.
    Feb 2005
    54
    Are you actually asking what an MPG is for?
    Mar 2007
    2083
    depending on the video standard of the original monitor you may find a converter to convert
    the Delta's RGB output (possibly with syncs on Green o/p ) to SVGA
    if the new SVGA monitor is able to lock to the Delta video line & frame rate
    you may only need a simple converter to convert the original sync signal to the separate Horizontal sync & Vertical sync for the SVGA input
    possibly a converter sold to connect a new SVGA monitor to old arcade games
    John
    1943
    Quote Originally Posted by rpseguin View Post
    Are you actually asking this question 15 months after this thread died?
    Feb 2016
    115
    Quote Originally Posted by 109jb View Post
    Do either of you even know what MPG stands for?lol manual pulse generator! I just googled it and google doesn't lie! LMAO
  1. Swap or No Swap? (mSATA drives)
    By grumpygeek in forum LinuxCNC (formerly EMC2)
    Last Post: 06-09-2015, 05:08 PM
  2. Successful participation in EMO Hannover 2013
    By SatishNaik in forum News Announcements
    Last Post: 12-03-2013, 06:25 AM
  3. I would love to see this forum be more successful.
    By KyleH2 in forum Community Club House
    Last Post: 07-04-2008, 01:23 PM
  4. Spindle motor swap, or servo swap?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 10-09-2007, 06:54 AM
