587,003 active members*
2,935 visitors online*
    Mar 2005
    10
    Brother Wire Edm
    What will happen if I try to power up wire EDM machine (Brother HS-3100) without connecting water tank to it ? I don't want to cut anything. Just want to see if I can move it in XY axes. Will machine let me do it, or there will be some kind of alarm blocking the whole machine ? Any precautions I should consider when starting this kind of machine for the first time ? I bought it used at auction so I don't know anything about it. The guy told me I should let technician take care of it. Is it necessary ?
    Jan 2006
    104
    dude, just hook up the flush cart, it only takes a few minutes....
    but i think the brother needs a di bottle hooked to it also, or just put
    bottled water in the system, to ensure it is clean(don't use tap water)
    if you don't put water in the system, the brother may alarm...(not sure)
    however the machine should boot to an input screen even without water,
    then maybe you can jog.....
    the brother expert is craig at edmnetwork
    go to edmnetwork.com
    sorry i can't remember all the nuances of the brother as i don't work on very many...
    good luck
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Mar 2004
    1543
    I've got a different brand, but you shouldn't be able to hurt anything by trying to move it. Mine will even let you try to burn, the wire just promptly breaks and then you get shut down for wire broken.
    Karl
  1. Spindle Repair-Brother TC-221
    By Ben Colby in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2023, 12:18 AM
  2. brother cnc 100
    By wratey in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2011, 11:05 AM
  3. BROTHER HS-70A Post
    By asylumua in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-12-2006, 11:54 AM
  4. Brother TC-215 CRT problems
    By Rufan in forum Uncategorised MetalWorking Machines
    Last Post: 03-29-2006, 09:23 AM
  5. Drip Feeding To a Brother (TC-218)
    By Igot2drip in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2004, 05:50 PM
