586,670 active members*
3,308 visitors online*
    Mar 2005
    21
    spindle speed control
    Does anyone have a schematic I can use to make a spindle controll board, and speed sensor for my homier minilathe? I am making a CNC board to do the "whole lathe" I already have the pport, two (x) & (z) axis, the coolant and spindle on/off relays designed in now I just need to add in these last 2 things. I am using other designs off the net and putting them together, I can mix and match but I am a ways off from actualy designing a board (or anything complex) that would actually function. So for now I am trying to use proven designs and see if I'm smart enough to put them together on a single board
    Thanks J
    :cheers:
    Mar 2005
    21
    That is what I need, but I am wanting to put everything on 1 board including the axis controllers. I am looking for a schematic so I can make my own custom board, I did not see those sold as "kits" If I could find kits (preferably) or a layout schematic (with connections) I could work from them and see the parts and how they connect to each other so I could incorporate them into my personal lathe board. I made my first pcb board (a 120vac relay) then a fuzz effect box for my guitar, and I got hooked, (at least its not drugs im hooked on!) I'm not making anything to sell lord knows I'll be lucky if I can even make it work..... I'm just wanting to learn and try something I can actually use.
    J
    Dec 2004
    1137
    Can't help with the speed control but the tachometer is easy enough:
    http://www.shumatech.com/products/dro-350/add-ons.htm
  1. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  2. How to control the speed of the main spindle?
    By george128306 in forum Hobbycnc (Products)
    Last Post: 04-15-2006, 10:00 AM
  3. Spindle Speed Control
    By bill south in forum Benchtop Machines
    Last Post: 02-24-2006, 07:27 PM
  4. spindle speed control
    By terrycrout in forum CNC Machine Related Electronics
    Last Post: 10-16-2005, 04:05 PM
  5. BP spindle speed control
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 06-15-2005, 03:06 PM
