586,055 active members*
4,376 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Grounding a 2.2kw VFD spindle
Results 1 to 7 of 7
    Aug 2015
    45
    Question Grounding a 2.2kw VFD spindle
    Hi everyone i have a cnc im building all metal frame metal everything and im having a few questions about grounding it properly.
    I have 3 core shielded wire i was going to sue for the spindle but that doesn't include a ground.
    My question is if the frame of the machine is ground then since the spindle chassis is touching the machine will it be ground or do i need to run a separate line from my spindle casing to the inverter ground?
    if so can i run a separate wire from ground to spindle chassis or does it need to be inside the shielding for RF noise problems/stepping issues?
    The spindle is a Chinese spindle and the inverter is a huanyang 2.2kw
    Thanks in advance
    Aug 2015
    142
    Re: Grounding a 2.2kw VFD spindle
    The best is if u use a shielded wire cable , and put ground on spindle case .
    Aug 2015
    45
    Quote Originally Posted by Andreiir View Post
    So I should get 4 core shielded instead of the 3 core shielded i have? I know it's the best way but just wanted to see if I could use what i have instead of buying another one
    Aug 2015
    142
    No need .
    If u have shielded wire cable u use shield for gnd to spindle .
    Aug 2015
    45
    No need .
    Isn't that technically a ground loop so there can be a chance of current flowing through the shield which is undesirable?
    Aug 2015
    142
    What is the use of shield if not for protection?
    Aug 2015
    45
    To properly shield don't you just ground at driver end then shielding works but its not used for grounding as such like a ground wire
  1. Grounding router spindle?
    By Mogal in forum DIY CNC Router Table Machines
    Last Post: 02-07-2022, 07:32 PM
  2. Help!!! Touch probe grounding through spindle???
    By Momentz in forum DIY CNC Router Table Machines
    Last Post: 11-28-2014, 10:21 PM
  3. Grounding or?
    By warrenb in forum Maintenance DIY Discussion
    Last Post: 02-28-2014, 03:39 PM
  4. Grounding the DC-K40
    By neptr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-28-2012, 06:00 AM
  5. grounding Q's
    By anthony in forum CNC Machine Related Electronics
    Last Post: 05-14-2005, 11:24 PM
