586,108 active members*
3,214 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Jul 2003
    168
    Big Red Kill Switch, where to get?
    I've looked at Jameco, Digikey, American Sci. & Surplus, Herbach and Rademan for a "Big Red Kill Switch."
    I'm thinking of something on top of the router you'd slap with your palm.
    How'd you handle emergency shutdown?
    Where'd you get the switches?
    Thanks.
    Dan
    Jul 2003
    168
    Like you always tell me:
    "Find it at www.mcmaster-carr.com."
    where I just found it.
    Thank you.
    Dan
    Jul 2003
    168
    Spoke too soon.
    My life is not worth $57.96.
    What can I get for a buck ten-eighty?
    Dan
    Apr 2003
    1079
    Did you check ebay? There's usually quite a few on there for cheap.
    927
    Allied Electronics
    here :
    http://www.alliedelec.com/cart/partlookup.asp
    Search for part #804-1500
    $22.44 ea. (4ea. instock.)
    Jul 2003
    167
    Nearly all electronics suppliers have this, search for emergency stop
    http://www.digikey.com/scripts/DkSea...413394&Site=US
    on ebay, search for e-stop or emergency stop
    927
    Jimbo,
    Nice 68 Olds cutlass
    Had one myself at one time.
    Mine had a 6-71 blower on it though.
    Apr 2003
    99
    Aug 2003
    53
    Princess Auto Parts sells emergency stop switches for about 10CAD$. They are online too. www.princessauto.com
    comes with double terminal.. one NO, one NC.
    Feb 2004
    36
    Pedestrian cross walk buttons work great!
    Just paint them red and don't get caught.
    Kidding
    Seriously I got a couple on ebay and they are great.
    Even better get a pull cord switch, like the ones on a bus or along conveyors and install a vinyl covered cable around the whole machine with little pulleys. This way you don't have to dive across the machine to hit it.
    I've also found that a foot pedal is very handy for an extra E-stop.
    Chris
    Jul 2003
    125
    Mini-lathes use these: http://www.littlemachineshop.com/pro...ProductID=1332
    The top red spring-loaded button slides back to open the lid; a slap turns it off.
    Jul 2003
    168
    I thank you all. I'll look them all up.
    It's not so much my life as the money my wife has got tied up in "the machine."
    I really like Chris's 'pull-cord' idea! I can foresee "ringing it around the machine".
    AJ_Mac2001, your post showed me how to solve my problem to ensure that "logic power always starts motor power."
    Dan
    65
    Automation Direct for like 11 bucks is where i got mine.
    Nov 2003
    79
    creative just as a safety thing, the switch you linked to is only a momentary switch, you want a switch that requries a intentional delibrate movement to reset. I like the pull cord idea or maybe depending on the use of the router, one of those little door beams that sound a chime
    65
    Here is the one I am using:
    EPO Switch GCX1131 $9.25
    AutomationDirect.com
    Mounted it in a little $3 plastic box I got at Radio Shack. Put it close to where you stand. for that matter, you can use more than one if you desire. Ideally, you should never be more than a "hand slap" away.
    Nicely made and very reasonably priced. I will post a picture of the completed unit.
    Twombo
    Aug 2003
    253
    Dumb questions:
    Model: GCX1226-120
    22 mm metal, illuminated, red, 120 Volt AC/DC, 40mm mushroom operator, latch with twist-to-release, 1 N.C. contact block
    Questions:
    1. Does this mean I don't need a latching relay? Or, do you always need a latching relay?
    2. If you have only one N.C. contact block, do you just run your hot side of the AC through it? Hit the switch and the power goes off? No other circuits needed?
    3. My Power supply takes 220V (which is really two 110V AC and a ground). Some of the Buttons at automationdirect have stackable contact blocks. I assume that means I could run the 220V through it by having each 110V side go through a single contack block. Is that correct?
    Thanks for any help...........Sam
    Feb 2004
    32
    Maybe someone already said this but any electric supply company will have or can get these. They are very common on equipment in manufacturing plants. I've bought bunches of them in the past. Unless you live in a very small town you will have one. Look under electrical suppliers in the yellow pages. Locally we have companies such as Sefco Electric, Irby Electric, Souther Electric, etc. These guys sell wire, conduit, switches, etc. Like I said, if they don't have it they can get it.
    BTW, find someone who works in a manufacturing plant and you can probably get one free. My old plant had a boneyard with bunches of control panels on the ground with these in it for salvage.
    BTW, do we have a for trade section anywhere? I've got to go see. If not maybe we should consider making a for trade forum. I can get all kinds of junk stuff like this to offer for trade. Manufacturing plants create a steady stream of "junk".
    John
    JTB
    Feb 2004
    32
    As I understand it most red panic type buttons in manufacturing simply cut the control power that makes the holding circuit, at least the ones I've used. I'm not the right person to design a holding circuit however so I can't comment further on what you will need. Sorry.
    BTW, you could make "friends" with the guy at the electric supply place and get him to help design the circuit. They often get into this kind of stuff and would find a home made CNC "cool". Just a thought.
    JTB
    Feb 2004
    36
    Exclamation
    I would always use a latching relay on the motor power supply.
    You can't trust a switch to stay off.
    Also it's a good idea to have a latch incase of power failure, breaker trip, or utility brownout. You don't want the router to start up again on its own when power is restored.
    If you are running 220v you must use a double pole switch. You have 2 hots to switch. If you only switch one pole some of your circuit will still be live! Zap!
    The "twist to release" E-stop is just used to add a little more safety to the latching circuit. It's not intended as a replacement for a latch.
    Another thing I like to do is use one of the NC poles on the latching relay to discharge the motors capacitors through a large resistor. This may be a good idea if you have a very large capacitor bank. It also in the case of servos prevents them from generating voltage as they spin to a stop.
    Chris
    Jan 2004
    8
    DigiKey look at Part# Z1427-ND $28.58 Z1428-ND $34.47
    Mouser Part# 642-A01ES $9.47 I have not used any of them but I found them when looking for a stop switch to use on a router.
Page 1 of 2 12
  1. Solid-State limit switch experiment
    By Swede in forum CNC Machine Related Electronics
    Last Post: 01-08-2010, 08:20 PM
  2. idea for limit switch, need opinions
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-29-2007, 12:59 PM
  3. limit switch override
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2004, 10:47 AM
  4. E-Stop Hard Wire and to Software?
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 10-30-2004, 05:22 AM
  5. Limit Switches
    By Mr.Chips in forum Xylotex
    Last Post: 02-25-2004, 04:13 AM
