586,076 active members*
3,799 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Flexible coupling for 4.5 mm ball screw shaft
    Jul 2016
    Hello all,
    I'm building my first machine. It will be a desktop sized build, built using mainly t-slot extrusions.
    I just got the ball screw I purchased of ebay for the Z-axis (this one: KSS Ground ballscrew FBS0801 255L Stroke 180mm Pitch 1mm CNC Router NSK | eBay). I'm now stuck looking for a coupling between the ball screw shaft and the stepper (NEMA 17 sized on the Z-axis).
    The ball screw shaft diameter is 4.5 mm, and I seem only to be able to find 4 mm and 5 mm. I do not have access to a lathe, so machining the shaft down to 4 mm is not an option. Are there any 4.5 mm couplings available, or is there any way of adapting a 5 mm coupling?
    Best regards,
    Jul 2016
    Re: Flexible coupling for 4.5 mm ball screw shaft
    Looks like I was jumping the gun on posting this one, sorry. I thought I had searched exhaustively, but moments after posting, I found a coupling for the 4.5 mm shaft for some $30 on aliexpress.
    Best regards,
    Jun 2005
    1730
    You might also consider getting a 5mm coupling and use a strip of aluminum from a pop can as a spacer.
    Russ
  1. Sale!!!Shaft coupling cnc router coupling coupler
    By zao in forum Want To Buy...Need help!
    Last Post: 08-29-2015, 07:59 AM
  2. Coupling stepper motor to ball screw
    By ahab8783 in forum Hobby Discussion
    Last Post: 09-14-2011, 09:19 PM
  3. FIX: motor shaft and drive screw alignment, coupling
    By fivefishcnc in forum DIY CNC Router Table Machines
    Last Post: 02-09-2009, 10:30 PM
  4. Coupling stepper to ball screw
    By garagefela in forum Linear and Rotary Motion
    Last Post: 08-18-2006, 11:51 PM
  5. Small hose clamps - screw to shaft coupling?
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 03-20-2006, 07:50 PM
