Hello Y'all,
I have a centroid retrofit on my Bridgeport Boss circa 1993.
The control stopped recognizing the Y+ limit switch. I have pulled the board and the limit switch circuit works all the way up to the plug in to the control. I know the switch works and know the wires are good. I have physically tripped the limit switch in the parameters mode and the control does not recognize the switch in one direction. I swapped the switches and it is always the same input at the control.
I am not an electrical guy but traced the circuit board as far as a could to make sure continuity was good.
Any advice would be greatly appreciated. Thanks.
