586,051 active members*
3,638 visitors online*
    Jul 2016
    16
    099 TOOL NOT FOUND IN TABLE
    Hi All,
    I have another problem that I can not figure. I am counter sinking three very small screws into a piece of stainless steel. Made a very simple program (see below) but when I go to "Run" the program it give me the error "099 TOOL NOT FOUND IN TABLE" (see below) But you can clearly see in the program that I have T1 selected. I have tried many things. Deleting the program and starting fresh, re-naming, editing other programs. The strange thing is that I was running this program when I burnt up a tool, changed a toll and re zeroed pressed run and now this. The old programs but not new ones. I hope someone can help on this strange one.
    By the way the new screen was super easy to install and worked perfect. These are also pics of the LCD.
    Jan 2009
    52
    Re: 099 TOOL NOT FOUND IN TABLE
    Not to be too obvious but did you check your tool table to see that you have a T1 in it. Not sure what type of machine you have this on but the Q table is used to hold tool numbers.
  1. Found way to sort/edit Tool Library with Excel
    By drutort in forum SprutCAM
    Last Post: 03-22-2018, 03:49 PM
  2. Replies: 4
    Last Post: 04-12-2014, 01:37 AM
  3. found xy table... want to make into wood router
    By randomeyes in forum DIY CNC Router Table Machines
    Last Post: 06-22-2010, 11:24 PM
