586,108 active members*
3,107 visitors online*
Thread: Compressor
Results 1 to 9 of 9
    Aug 2005
    7
    Compressor
    Is it possible to cnc mill your own compressor? I have been reading the forum and it seems you guys all buy them. How about the turbine?
    May 2006
    2420
    I have seen the diffuser blades milled, without CNC control.
    Have you read Shreckling's book on model gas turbines ? His method uses timber construction (small good quality plywood) for the compressor wheel. Its worth a read even if you don't intend to build using his methods.
    I have building a gas turbine on my list of things to do, just too many things higher on the list at the moment.
    Russell.
    Aug 2005
    7
    I just ordered it along with Mike's Jet Book and Model Jet Engines by Kamps.
    May 2006
    2420
    That should keep you busy for a couple of days...lol
    Russell.
    Apr 2005
    281
    Although I think you could make the compressor on a cnc I think you may have problems with the curves on the blades. Also the balancing as out of the box they are ready to go. The turbine can also be made and you have the books for help but I purchased mine for the same reason as above and I have a certification for 125k's so it can be flown under MAAC rules in Canada. Not sure if they let them in the USA yet. Lots of regs.
    John
    Aug 2005
    7
    if as you say the compressor can be made out of wood. do you think it would work as ABS plastic? i think i can get access to a rapid prototyping machine. or it can do wax so i might be able to lost wax cast one in aluminum.
    Apr 2005
    281
    The compressor that is made from plywood(aircraft) is also reinforced with carbon strands wrapped around the circumferance. I believe if you read up on it you are limited to 80k which is good to see one working. Just not enough thrust for most models but a great conversational piece. Plastic won't take the stress and I was going to make the front cover for my KJ's but got advised not to when I was with the GTBA. Some guy's had already tried that route.
    Never thought of casting one but that would probably work if it is done right.(ie the blade curvature and profiles) Be advised there are different blade profiles on the same compressor.
    John
    May 2006
    2420
    I believe the Shreckling puts out about 6lbs of thrust, not much by today's model turbine engine standards but you could fly it if you had enough runway to get off the ground.
    With the carbon fibre strands, I was wondering if you could use the braided fishing line instead, it has huge tensile strength for its size, (50lb breaking strain is smaller than "normal" size cotton) and would probably glue quite well using the same methods as Shreckling uses for the carbon fibre's.
    Not that I am planning to make one in the near future, but it is the dream...
    Russell.
    Aug 2005
    7
    There’s multiple blade profiles on one compressor? wow
    That will be fun to try to accurately draft in the computer considering I’m trying to learn as I go. Haha
  1. DIY air compressor
    By joecnc2006 in forum Hobby Discussion
    Last Post: 07-05-2014, 07:11 AM
  2. rotary air compressor
    By omegaghost in forum I.C. Engines
    Last Post: 01-15-2007, 01:19 AM
  3. Compressor wheel
    By Chubs in forum Hobby Discussion
    Last Post: 11-04-2006, 01:19 AM
  4. homemade air compressor
    By jderou in forum Mechanical Calculations/Engineering Design
    Last Post: 09-18-2006, 02:26 PM
  5. Help! Getting the oil out of my compressor lines
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2006, 12:16 PM
