586,116 active members*
3,440 visitors online*
Results 1 to 9 of 9
    Oct 2010
    670
    Coaxial Indicator
    So... was at the Tormach open house and was shown the Heimer coaxial indicator for dialing in your drills and boring tools on your gang tool. My question is, which version do you folks recommend. At nearly $600 I just thought the 3 axis Heimer was high (even though I own one and love it).
    Tormach version $550:
    Haimer CENTRO Precision Centering Device
    Travers $220:
    Co-Ax Type | Travers.com
    Thoughts? Or other ideas for a fairly new guy. A better way to skin the cat????
    Later,
    Awall
    The Body Armor Dude - Andrew
    May 2006
    143
    Re: Coaxial Indicator
    Quote Originally Posted by smokediver576 View Post
    Travers $220:
    Later,
    Awall
    Since you wont be using it very often i would just get a cheapo.
    I got this for 60 bux on amazon:
    https://www.amazon.com/All-Industria...xial+indicator
    looks same as the tavers. Works well and free shipping if you have prime.
    Get some nicer tooling with the money saved imo.
    Jesse
    Nov 2007
    2151
    Been looking at one for a while. Would like one for finding centers more accurately on mill and for future lathe setups also.
    May 2015
    111
    I got mine from Enco for about $85. It works well. I use it in the lathe all the time.
    Buy Centering Test Indicator Sets (607-4907) from UseEnco
    Jun 2006
    3063
    I have a used Blake co-ax indicator in addition to a Haimer 3D Taster and usually the Haimer when finding the ID of bores or the OD of bosses in the mill. I prefer the Haimer to center gang tool holders as well. Maybe my Blake got abused by the previous owner but it doesn't seem to find centers as accurately as the Haimer.
    From what I've read the import co-ax indicators aren't as well built as the actual Blakes and tend to have a rough movement but that may depend on the QA for a particular import source.
    Nov 2007
    2151
    I like German made tools period! My hamier probe was well worth the money. And I see no difference with the center finder system. Precision is everything in this craft.
    Oct 2010
    253
    I just use a dial indicator to sweep the holes in the tool holder. I use a three position tool holder which is on 1.25 centers (2.5" because of diameter mode) in theory. Real world, they are slightly off, so if you sweep all three and get the variances, you can make a note and put it on a sticky note ( or dymo tape ) on your monitor. In my case hole 1 to hole 2 is 2.5004 ( diameter mode ), 2 to 3 is 2.4997, 1 to 3 is 5.0001. This way, before a run, you only have to sweep the first hole and apply the correct offsets for the other two in your tool table. I use a Haimer on the mill, and this thing is just gold. I never thought of using it to center that first hole, but it's a great idea.
    Nov 2007
    2151
    Very true adamvs!
    I just watched ox on youtube sweep with an indicator and a little lever attachment! very cool very simple.
    Sep 2013
    55
    Quote Originally Posted by adamvs View Post
    I can never get my dial indicator even close enough to sweep my gang block holes.Seems like you'd have to be really close to even start sweeping with an indicator?
  1. COAXIAL INDICATOR
    By tjd10684 in forum MetalWork Discussion
    Last Post: 01-18-2019, 12:51 PM
  2. Coaxial High Speed Spindle for 1100
    By GLCarlson in forum Tormach Personal CNC Mill
    Last Post: 05-29-2016, 10:32 PM
  3. about centro/coaxial watches
    By deadlykitten in forum Okuma
    Last Post: 02-05-2016, 04:14 PM
  4. Coaxial indicator
    By scrambled in forum HURCO
    Last Post: 12-15-2013, 09:01 AM
  5. Best Coaxial indicator to buy?
    By aaron p in forum Community Club House
    Last Post: 03-05-2009, 08:30 AM
