Hello from a newbie.
I recently bought an old Amada 244 with Fanuc 6m and up to now not a single sheet can be worked through without some error messages that have no solution even if I call local amada technicians.
Almost every time after a clamp repositioning the machine stops with a message 06 interlock on the screen. It can only be cleared out by cutting the power from the NC and a restart after a while. Nowadays I also get a "index not prepared" message. The index pin does not move in manual mode even if I turn it to either direction. And the turret can not be driven to origin.
Is there any simple fault that could cause this. X and Y can be driven to origin, turret and AI not.
Thanks in advance.
