586,108 active members*
3,236 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > spindle rotate during G83 canned cycle
    Oct 2010
    30
    Spindle is starting during G83 cycle with live tool and C-axis engaged. C-axis and spindle are try to work at the same time
    Oct 2010
    30
    Re: spindle rotate during G83 canned cycle
    It's HAAS TL-25
    Aug 2015
    108
    Radial or axial live tool?
    G83 Peck drill should work as normal for a Axial tool
    If its a radial or side tool then you have to use G243.
    Did you engage the C-axis with M154?
    Here is a working code for using a Axial tool with a G83 peck canned cycle.
    O00000
    G20
    (TOOL - 7 OFFSET - 7)
    ( 1 INCH DRILL)
    (C-AXIS FACE DRILL)
    G00 T0707
    G17
    M154
    M8
    G00 G54 X0. Z.25
    C0.
    G97 P250 M133
    G98 G83 Z-1. R.1 Q.075 F4.0
    G80
    M9
    G00 Z.25
    G00 X8.
    G00 Z8.
    M135
    M155
    T0700
    M30
    Here is for a G243 Radial peck cycle.
    O00000
    G20
    (TOOL - 9 OFFSET - 9)
    ( 1 INCH DRILL)
    (C-AXIS CROSS DRILL)
    G00 T0909
    G19
    M154
    G00 G54 X4. Z-.8
    C-90.
    G97 P250 M133
    G98 G243 X1. R3. Q.075 F4.
    G80
    G00 X8.
    G00 Z8.
    M135
    M155
    T0900
    M30
    Oct 2010
    30
    Problem was in Parameter 315 bit 1 NO SPIND CAN CYCLE
  1. Rotate a G150 pocket cycle
    By JWK42 in forum Haas Mills
    Last Post: 11-01-2023, 04:51 PM
  2. G72 canned cycle
    By 60rock in forum Mastercam
    Last Post: 10-25-2014, 09:39 PM
  3. M-Spindle Canned Cycle Help Needed
    By Ecmdrw5 in forum Okuma
    Last Post: 10-17-2011, 12:22 PM
  4. TL-2 IPS Canned Cycle
    By gtkemp in forum Haas Lathes
    Last Post: 06-06-2011, 01:58 PM
  5. G76 Canned cycle
    By Stebedeff in forum Fanuc
    Last Post: 02-07-2008, 06:42 PM
