586,108 active members*
3,196 visitors online*
Results 1 to 18 of 18
    Oct 2004
    41
    Yaskawa CACR-SR
    I have the Yaskawa CACR-SR 15 E servo drives on my CNC.
    One of them blew a few bits up and I have had it repaired.
    Problem is when I power up the CNC it comes up with an A02 error which according to the book is " missing parameter".
    Can anyone help as to how the heck I can reset the parameters, or indeed how this thing should be set up.
    CNC is a SCM Record 2CE this is on the X axis
    Help, help, help
    chr:withstupi is f
    Jul 2006
    103
    I'm Mad At Yaskawa!
    I sent in a drive to be repaired, they sent it back "repaired they said".
    had serious problems on that axis with the "repaired drive".
    called them and they said "we checked everything it's good".
    swapped the drive to another axis and the problem followed the drive.
    called yaskawa again they said "everything is good with that drive".
    called them again hopeing to get someone with some common sense,
    and that guy said send the drive back.
    sent the drive back, got it back. SAME THING!!!
    called yaskawa again they said "they checked everything, and even checked it under temp extremes".
    called them again, finally got someone who knew something "WHEW! i thought" he told me about a parameter that is protected and you have
    to do some keystrokes in a certain order to access and change.
    he told me the strokes and the correct setting and also told me
    not to tell anyone this.
    changed it, NO JOY!!!!!!!
    well needless to say the owner is getting pretty upset by now.
    soooooo. we got another repaired drive from another supplier, plugged
    in the correct settings, "including the HIDDEN ONE" wallah machine
    runs perfect.
    (nuts) to yaskawa.
    oh yeah your gonna have to call them
    Jul 2006
    103
    by the way they tried like hell to send a tech down BEFORE
    they told us about the hidden setting THEY changed!!!!
    (flame2) to yaskawa.
    Dec 2006
    7
    I must ask at this point, Riverrat, what is the parameter, where is it located-drive or controller, how do I access it?
    Jul 2006
    103
    its in the drive and it depends on the drive.
    the ones i've dealt with you have to have an interface, which is
    simply a hand held keypad that plugs into the drive.
    to access the locked out parameter you have to do a certain
    keystroke on the keypad, i wrote it down and it is at work.
    why ya askin, got a yaskawa drive that you sent in?
    orrrrrr, ya think i'm fibbin.
    Dec 2006
    7
    Just tryin to break into the yaskawa line of servo's and started with CACR's. I hate tricks like that but seems many incorporate it to generate revenue.
    Jul 2006
    103
    off of the top of my head i believe the one on one of our ez paths is the sdgb, sgdb line, one or the other
    on that. the keystroke, from memory again is "on the digital operator"
    down arrow three times, up arrow two times, enter two times.
    then you can acces param. cn6a.
    that might be a little off if you need it correctly i will copy the procedure
    and let you know for sure tomorrow.
    dino
    Jul 2006
    103
    i was close.
    it's
    depress hold jog and keep it depressed
    bb, base block
    up arrow two times
    data enter two times
    param
    that unlocks param cn6a
    on our ez-path II the setting they changed was 842A, they changed it to
    840A, it has an SGDB-O5AD drive.
    all of the "user accesable" parameters they changed back to the
    original setting.
    that little hidden setting really peed me off, now if it has a yaskawa
    drive in it, they can keep it.
    Dec 2006
    7
    The Yaskawa drives I have been playing with are the CACR-pr & CACR-sr. I think the parameters in these are only configurable with jumpers. The only thing I can't get them to do is accept a incremental encoder other than 1000ppr or 1500 ppr. Maybe if I stay with these old school drives I can stay away from that hornets nest you experienced. Only problem is I have to get matching motor-encoders to use them.
    Sep 2008
    19
    I've only seen this issue with the Bridgeport machines. From what I understand, the Bridgeport controller can not see the encoder C-Pulse being sent from the drive. So changing this param tells the SGDB drive to send a wider pulse so that the controller can see it.
    All other controls (that I have seen) read this pulse fine...without the hidden parameter adjustment.
    Hope this helps...
    CNC Guru Guy
    Sep 2012
    Hi i am just getting into these servos repaired a couple does any body know which software i can download to test on my laptop servo cacr-sr20sb1csy
    Sep 2012
    Hi does anybody know which cable i need for my yaskawa servo cacr-sr20sb1csy i am trying to hook it up to my laptop using the software sigm win+
    May 2008
    Re: Yaskawa CACR-SR
    User constant cn00-0005...motor parameters modifications
    .....how....
    Aug 2011
    11
    Re: Yaskawa CACR-SR
    Quote Originally Posted by flinty View Post
    Help, help, help
    chr:withstupi is f
    The same happens to me.
    Have you achieved something
    May 2018
    Re: Yaskawa CACR-SR
    please can you help .
    i have error A02 with yaskawa servo drive .
    how to change motor parameters in yaskawa cacr-sr ?
    May 2018
    Re: Yaskawa CACR-SR
    Quote Originally Posted by jackeyteh View Post
    .....how....
    i have the same problem
    did you change the parameter and how ?
    15362
    Re: Yaskawa CACR-SR
    Quote Originally Posted by djohn View Post
    Not true, it is locked out for a reason, and they are not a secret, they are there only if you are a programmer and have been working with and trained in the use of the control software, if you go in there and change any parameters, without knowing what each one does, you will be in a worse mess, which I suspect what happened to riverrats Drive, there is normally no reason to unlock the hidden code, unless someone has gone in there and messed it up
    So if you know the drive, or what you are doing and working on all the normal Parameters that you have access to are all related to the hidden software Parameters, so everything that needs to be set Parameter wise anyone who wants to can play and see what works and what does not, this is where most get messed up, but there is always a RESET CODE that will change all the messed up Parameters back to the DFAULT
    Not sure why you would be wanting to mess with any old CACR's, they are so out dated that there would be very few that are as old as the drives that are still around that could help you with them , there is still some out there on old machines, and some so called " Repaired " drives available at a crazy price
    Mactec54
    15362
    Re: Yaskawa CACR-SR
    Quote Originally Posted by riverrat View Post
    i was close.
    it's
    bb, base block
    up arrow two times
    param
    original setting.
    You are dealing with drives that are more than 30 years old, somebody messed with your drive Parameters to start with, its very easy if you know what you are doing, please find some other manufactures drives that are still running after this many years
    Mactec54
  1. Yaskawa CACR-PR-02-AC3-FR Help please.
    By ercdave in forum Servo Motors / Drives
    Last Post: 10-13-2016, 05:24 AM
  2. Documentation for Yaskawa CACR-SR-10SB1AF?
    By rcooke in forum Servo Motors / Drives
    Last Post: 01-09-2014, 10:58 PM
  3. Initializing servo amplifier Yaskawa CACR-IR30
    By ing.vic in forum Servo Motors / Drives
    Last Post: 09-02-2012, 10:31 PM
  4. yaskawa CACR HR10SB servo pack
    By vipansam in forum Servo Motors / Drives
    Last Post: 12-07-2009, 05:39 AM
  5. YASKAWA CACR SR CACRSR
    By JASEPH in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2009, 05:48 PM
