586,033 active members*
2,894 visitors online*
Results 1 to 13 of 13
    Jul 2015
    27
    Looking for used Tormach Slant Pro
    Looking for lightly used Tormach Slant Pro. I'm in the Pittsburgh, PA area and able to drive around 500 miles approx. Thanks.
    SPCNC
    Nov 2005
    218
    Re: Looking for used Tormach Slant Pro
    Good luck. I've been looking for one for months. If you find one on the west coast please let me know.
    Oct 2010
    253
    Quote Originally Posted by grimms3 View Post
    SPCNC
    Good luck, people seem to be holding onto these things.
    Jul 2004
    595
    Quote Originally Posted by adamvs View Post
    Yep! I was lucky enough to find one used and Im not letting go of it any time soon
    Nov 2005
    218
    There is one near Indianapolis. The seller does not seem very willing to work with a remote buyer, but if you are willing to pick it up this may work for you.
    https://terrehaute.craigslist.org/tls/5708603778.html
    Jul 2015
    27
    Thanks. I was too late seeing the post. New 15L in the corner of the garage now and finalizing tooling setups. Seems to be quite fast. No wonder there's none used for sale.
    It's happy sitting next to the 770!
    I'll keep a watch and let you know if I hear of anything.
    Jul 2004
    1424
    congrats on the new purchase. Looking forward to reading your impressions and seeing your work.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Jul 2015
    27
    I'll try to post some of the "beginners blunders" to keep things interesting.
    Blunder 1:
    Stopped a parting operation since the cut was way too aggressive. Space bar and Stop. So far so good. G30 was set from the PP screen.
    Then pressed the goto g30 on the screen. Woops good thing the insert pops out. Replaced and it's ok. Need to look into setting an intermediate step to get to tool change position. ie: move back in X then goto Z. Checking on this tonight to see if the PP screen G30 set can contain an intermediate position like the G28 gcode.
    thanks.
    Jun 2006
    3063
    If you use flood coolant watch out for leaks out the back end of the spindle. I somehow manage to get coolant past the 5C collet and closer on solid stock and tubular stock was nearly a disaster.
    Jul 2015
    27
    So far no coolant issues thanks.
    Blunder 2: QC tool post moved: Use a big wrench on the quick change post. Got a bit aggressive with drill and it moved the post. Cleaned the bottom, removed the oil, tightened with large wrench. Re-aligned and it seems to be ok. Considering milling a plate with some set screws to put on the bottom of the QC post. Maybe this will help to keep it in coaxial adjustment if it's bumped a bit hard.
    I had some bizarre repeatability and found that the post had moved slightly before I used by coaxial indicator. The coaxial shows about 1/2 thou. and I thought I was ok. Then drilling was absolutely wild. Visually it was wayyyyyy off. That's what started my looking into the source. Make sure the post is tight tight. Check often. I'm also going to use a gang plate for drill ops. It should easily handle the forces based on its design.
    Jul 2004
    1424
    Maybe modify your QCTP so it has dowels to keep it from rotating? The Dorian QCTP come pre-drilled for them, I believe. Since the QCTP mounts on a riser plate, it should be relatively easy to drill it with holes to accept the dowels.
    Tim
    Oct 2010
    253
    Quote Originally Posted by tmarks11 View Post
    I've had a Dorian QCTP from the get go, and have it pinned to the riser block: it ain't moving. Repeatability, 'floats' in a .0004 diametric window; you'll get a few parts dead on, then the next is off by .0002 to .0003. I think this due to the fact the tool doesn't always repeat perfectly in the 'Y', or the stop height. I also milled a few slots on the bottom of the riser from the threaded holes for drainage. All in all very solid. Dorian, is highly recommended.
    Jul 2015
    27
    That's a whole lot better design idea. Looks like a mod is in order. thanks.
  1. Knurling on the Tormach Slant Lathe
    By Spiffy Lab in forum Tormach Slant Lathe
    Last Post: 06-12-2016, 06:52 PM
  2. Tormach SL15 Slant Pro CNC Lathe
    By DelMarVa in forum For Sale Only
    Last Post: 02-16-2016, 01:44 AM
  3. TORMACH 15L SLANT-PRO CNC Lathe: Unbox and Setup Log Video
    By s2jesse in forum Tormach Slant Lathe
    Last Post: 02-15-2016, 06:33 AM
  4. Tormach Slant Bed Lathe Demo
    By MichaelHenry in forum Tormach Slant Lathe
    Last Post: 05-14-2014, 09:55 PM
