586,444 active members*
3,193 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > Toolpaths below surface using HeeksCAD/HeeksCNC
    Jun 2014
    17
    I'm trying to use HeeksCAD/CNC for generating toolpaths and G-Codes but there's something wrong because toolpaths are below the solid surface in certain areas:
    How could I solve it? How can I change the toolpaths resolution/tolerance (which is "Distance along paths" in BlenderCAM)?
    Thank you very much in advance,
    Jun 2014
    17
    Re: Toolpaths below surface using HeeksCAD/HeeksCNC
    I partially solved it. It seems HeeksCNC converts the original objects (imported from a .step file) to STL format temporary files and calculate paths using those files. I imported the objects individually as STL objects with a 0.01mm tolerance (default is 0.1mm) and now the paths look OK.
    Look at the picture below:
    Attachment 332000
    Is there anybody of you using HeeksCNC? I'd love to be able to modify the overall tolerance as most of CAM software do. I tried changing all parameters in the machining options but I always get the same number of lines. I'll really appreciate your help.
  1. anyone tried heekscad / heekscnc for CAM?
    By autobot in forum Uncategorised CAD Discussion
    Last Post: 09-11-2011, 02:35 PM
  2. reversing toolpaths on surface contour
    By galaxyman7 in forum Mastercam
    Last Post: 02-21-2010, 09:50 PM
  3. Surface pocket toolpaths
    By jcnewbie in forum Mastercam
    Last Post: 10-24-2009, 11:25 PM
  4. Surface Toolpaths
    By Flying Scot in forum Mastercam
    Last Post: 02-06-2008, 01:06 AM
  5. Surface toolpaths Help
    By Julian M in forum Mastercam
    Last Post: 10-06-2006, 09:31 PM
