586,108 active members*
3,212 visitors online*
Results 1 to 10 of 10
    Jun 2014
    11
    Laser power "fatigues" during sustained cut
    OK, I'm cutting 1/32" neoprene rubber (but have noticed this problem with other materials as well). I'm making a gasket, 14" x 1" with 100 rectangular holes that are approximately 0.125" tall and 0.075" wide. As the laser progresses further into the cut the power apparently "fatigues" so that while the first holes are fine, the last 20 or 30 do not cut all the way through. The panel meter remains steady as far as I can see. The outline cut starts out fine, but by the end (inch 30) the cut is not through. Speed is 10, power (set) is 60%. I found that if I "pause" after every five small holes and immediately restart, all holes are fine. If I pause every 5 seconds of the outline cut and immediately restart, it too is fine. What's the problem and how do I fix it? Thanks.
    May 2015
    53
    Re: Laser power "fatigues" during sustained cut
    Quote Originally Posted by RedDawg View Post
    Check if the ammeter power is falling on it, if the problem is with certainty the power supply ....
    Now remains constant power on the ammeter during the cutting period there most likely be the laser tube ...
    The use of time has its laser tube?
    Enviado de meu ASUS_Z00AD usando Tapatalk
    Nov 2008
    643
    Smoke buildup in the machine?
    Jun 2014
    11
    Quote Originally Posted by Dean448 View Post
    No, no smoke. The odor of the neoprene being cut is quite noticeable but any smoke generated is quickly and thoroughly exhausted. Probably fewer than 300 hours on the tube. I think the "telling" clue is that a "pause" of as little as 1 second "resets" the power for another 5-10 seconds of cutting before it starts to fade again. I'm leaning toward a problem with the high voltage supply but I don't know what the nominal value for that should be (and the docs don't help) or how to go about measuring it without a high range voltmeter. Even if that is the problem I would think the panel ammeter would show a noticeable decrease if the HV to the tube is also declining. I'm guessing from the quality of the cut that the delivered power to the material is falling by at least 50%.
    Nov 2008
    643
    Other then the method you are using I haven't seen a safe way to measure the output of a PS. Any chance the control voltage into the PS is steady? Are all connections to the tube secure? Any leakage to surrounding metal?
    Feb 2007
    31
    Are you using a CO2 laser? If so, how are you cooling it? Water temp might be too high.
    Jun 2014
    11
    Quote Originally Posted by jeepers94 View Post
    Sorry, should have said, yes it's CO2. Uses the factory water chiller which typically reads 34-35° C, just slightly above room temperature. Even if that is too high, I can't see a one second interruption every 5 seconds causing a recovery.
    May 2015
    53
    What is the power of laser tube? This temperature is too high, you should try to work at least 24 ° C ...
    Nov 2010
    787
    34-35° C is much to high. Should be around 22° C or less.
    CNC lasers, constructions, service
    Jun 2014
    11
    Quote Originally Posted by rodrigomartins View Post
    I misspoke, it's running at 28 deg. C, 80 watt tube. I still don't see that a "rest" period of 1 sec. is going to change the temperature of the water by any observable amount, hence I don't see that as having a variable degradation effect. Too hot and I can see an overall fall-off of the power, but it should be gradual over time and remain there and not "recover" from a 1 sec. off period. The manual says operate at 35 deg. C. or below, so it's in range.
  1. Replies: 0
    Last Post: 12-15-2015, 08:01 PM
  2. Replies: 0
    Last Post: 11-10-2014, 04:26 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. original "laser" & "mulrec" files
    By medmouncef in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-10-2012, 08:38 AM
  5. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
