586,115 active members*
3,340 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Modified Fusion 360 Post for the Tormach Rapid Turn
Results 1 to 6 of 6
    Feb 2007
    27
    Talking Modified Fusion 360 Post for the Tormach Rapid Turn
    Hi Guys-
    Attached is the current Fusion 360/Slant Bed Lathe post that I modified for use on the Tormach Rapid Turn.
    Essentially I changed the code that would force it to use negative X values. Works fine here, but use at your own risk :-).
    Matt
    Jul 2016
    140
    Re: Modified Fusion 360 Post for the Tormach Rapid Turn
    Thank you!
    May 2013
    20
    Thanks. One issue I found is that when using the turning thread op that the canned cycle (G76) used the wrong direction now for thread depth. Maybe it's better to use the standard Slant Bed post and just flip the X direction in the Fusion 360 Cam setup?
    Jan 2011
    15
    I am not sure if this thread is still alive but I am running out of options.
    I built my own rapidturn, conversational works fine but the posted files from Fusion are messed up.
    I have tried different post processors, none of them works 100%
    The file seems fine but it looks like it mess up radius/diameter because all the files I post have the curves at half the radius distance. (if that makes sense)
    I just tried the post processor posted here and this one posts the correct diameter but the radius is the wrong way. (see picture)
    Can anyone help me out here, I am out of ideas.
    May 2009
    9
    Quote Originally Posted by flatsix66 View Post
    You can easily change the I direction by editing this post and changing line 1821 to
    var iVal = ( driveLine - threadCrest ) * -2;
    The function _calcThreadPasses seems very complicated. Does anyone know how it is trying to calculate the J value?
    Sep 2009
    1856
    Have a look on the HSM forum there are quite a few post there for the tormach lathe and mill
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  1. Tormach Rapid Turn / Path Pilot parting question/ bug??
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 08-30-2016, 06:08 AM
  2. Fusion 360 Post Processor for Tormach PCNC1100
    By Gerry Kmack in forum Tormach Personal CNC Mill
    Last Post: 02-05-2016, 04:48 AM
  3. Tormach Post and Fusion 360
    By grimms3 in forum Tormach Personal CNC Mill
    Last Post: 10-20-2015, 04:58 AM
  4. How to turn on the conveyor--99 Fusion Lathe
    By accuratecnc93 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2009, 05:38 PM
  5. Boss 4 How to turn down rapid?
    By jodybo in forum Bridgeport / Hardinge Mills
    Last Post: 03-21-2008, 06:33 PM
