586,110 active members*
3,162 visitors online*
Results 1 to 9 of 9
    Jan 2016
    10
    HELP with cnc
    Dear All,
    I have recently bought a CNC 1224 for woodwork from China. I am facing an issue with engraving and even my bits reaching the MDF. I have installed all the electric work and the machine starts fine, goes to REF point great. My machine starts engraving inches away from the material. Let me explain the steps and see if i am missing any.
    1. Turn on machine
    2 go to REF point (homing)
    3. move machine to materials and press XY=0 and Shift + 0 to clear Z.
    4. when i press the play button the machine moves but the BIT DOES NOT reach the table or the material so it basically engraving on airl
    PLEASE HELP!
    Mar 2016
    325
    Re: HELP with cnc
    Do You hawe a tool change in Your program? (line with T address) If You have it remove it unless You use multiple tools, but anyway for start just try program without TC.
    Chechk if Your Z0 remains on planed face after You run program.
    Jan 2016
    10
    Re: HELP with cnc
    Thanks for your email. I have a NK105 control but no tool changer. How do i check my Z 0 remains face?
    Dec 2012
    390
    Re: HELP with cnc
    Where is Z0 on your model? Did you move the tip of your cutter to where Z0 should be and zeroed the Z DRO? If Z0 is top of your stock, did you move the cutter so it just touched the top of the stock and zeroed the Z DRO?
    Mar 2016
    325
    Re: HELP with cnc
    Even if You don't have tool changer The NC system may use some tool data which can be defined somway and it may add some tool length while selecting one in program.
    I assumed that Z coordinates are defined in correct direction.
    To check if Z0 remains in the same point You can touch part at known height and check the Z coordinate or go to some height above known pozsition and measure it by some measuring plate (it doesn't have to be real gauge block,- any piece of material with known height will be sufficient)
    Jan 2016
    10
    Re: HELP with cnc
    Hi its seems to work but accidentally reset the parameter and now it was moving fast but i managed to get the X,Y. pulse back to the origianly set point but how do i set tablet size on NK105 control
    Apr 2013
    1899
    Re: HELP with cnc
    Quote Originally Posted by vaskenet View Post
    Try to read the manual.
    http://am.co.za/router/panel/nk105.pdf
    Jun 2005
    11
    Re: HELP with cnc
    Make a short program: Cuts a line at Z=0 from XY=0,0 to XY = 10,10. Post the program (.nc file ) here.Can't diagnose sickness without examing patient.
    Dec 2005
    596
    Re: HELP with cnc
    Hopefully he figured it out within the last 6 years.
