586,052 active members*
4,323 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad Post Processors > Need post processor for samsung SL30 lathe
Results 1 to 15 of 15
    Jun 2016
    9
    Has fanuc OI-TD control 2 axis. Samsung SL30 machine for bobcad v27 lathe
    The processors that I have down loaded cant get canned cycle format wright
    The u and w in second line of g71 does not match what is in z allowance and x allowance
    Have tried editing processor but cant get it to change
    Dec 2011
    361
    Re: Need post processor for samsung SL30 lathe
    cmwincvp,
    Do you know if your lathe is setup to run two line canned cycles like the output you are showing?
    Jun 2016
    9
    Yes I can hand code it in the lathe and it will work. If I install file from cam in lathe I have to change the u and w output.
    Dec 2011
    361
    cmwincvp,
    Ok, I think I know what your issue is. In V27, there was an issue with the U and W reversing the values they grab, so Z was always U and W was always X. Please attach your post processor and I will correct the output for you.
    Jun 2016
    9
    U output needs to be U0.0100 and W 0.003.
    Dec 2011
    361
    cmwincvp,
    I need the post processor you are using so I can correct that issue so the correct values output. Please attach it to this ticket in zip format and I will get it updated and will attach the updated post processor for you.
    Jun 2016
    9
    Here is file
    Jun 2016
    9
    Here is zip file
    Dec 2011
    361
    cmwincvp,
    What I did was remove the callout for the rough_x_allowance and rough_z_allowance variables, and substituted it for the finish x and z allowance variables, which function the same as the rough variables, but instead of getting mirrored values, it outputs the correct allowance values. Give this a try and let me know if you have any issues with it.
    Attached Files Attached Files
    Jun 2016
    9
    Hello Sean, Loaded file and this is what I got N45 G71 P50 Q65 U0.02 W0.003 F0.015. Note U is giving me double amount of what X is in cam.
    Z amount is correct. U should read .0100 About a week ago I change line 249 to r and it changed U to correct amount but it changed all the X readings to. Had to change it back to d.
    Dec 2011
    361
    cmwincvp,
    This post processor should work the way you need it to.
    Jun 2016
    9
    Hello Sean, Loaded file and it works great!!!
    Thanks a lot! Great to have someone like you to help!
    Jun 2016
    9
    Hello Sean, I have another ordeal with default rapids. On Home Position X if I put in 5.00 in cam it will post 10.00 from processor.
    N300 X10. in pic. It needs to match cam.
    Dec 2011
    361
    cmwincvp,
    I cannot do anything to correct that. You will need to set 1/2 the amount for the home position you want in X.
    Jun 2016
    9
    Ok. Thanks for the help.
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Hello!! Allarm 012 samsung cnc lathe PL25A
    By Erpatata79 in forum Uncategorised MetalWorking Machines
    Last Post: 05-27-2020, 05:53 PM
  3. Samsung Lathe to network
    By bigbobr in forum USB, RS232, PARALLEL etc
    Last Post: 04-11-2013, 03:07 PM
  4. Replies: 0
    Last Post: 04-20-2009, 11:42 PM
  5. Samsung PL10 CNC lathe , Need Manual
    By Larken in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2008, 04:43 PM
