I am building a fabric cutter, and I need the the 4th axis to turn the rotary blade tangent to the line it is cutting. I tried setting the machine for 5 axis head/head configuration and modified the post processor, but no luck. It would not produce the g-code for the 5th axis (my 4th axis).
Here is my configuration:
1. I own Madcam 5.0 4X. I am not sure that I would need madcam 5X, so I down loaded the trial version on another computer to test the 5th axis functions.
2. I set the machine to be a 5 axis head/head machine, similar to what was explained in http://www.cnczone.com/forums/madcam/211984-cnc.html . In this post, it uses a table-head machine, I tried both the table-head machine and the head-head machine. I would think that I would use the head-head machine since the icon of this machine shows that the head can be rotated. In the icon, it is labeled "C". This is the axis I want to control, not the "A" axis of the head-head machine.
3. I made a test profile that is rectangle with one end a semi-circle. Looks like a Popsicle, but without the stick. Theses are just curves on top of a plane surface, not a solid.
4. Set up the machine for a 5 axis head-head machine and set the advance settings to:
Rotational axis 1 direction (1,0,0), angle vector (0,0,1) min. angle 0, max angle 120.
Rotational axis 2 direction (0,0,1) angle vector (0,-1,0) min angle -360, max angle 350 origin (0,0,0)
5. Here's where I start to go astray. I first tried 4-axis profiling with the forth axis set to indexed 0 degrees ( I tried all angles). The cutter was lying flat on the plane, not perpendicular.
6. Next I tried 5-axis profiling in indexed mode using the trial version of madcam 5x. I was able to chose top for the direction of the index, and the tool was in the correct direction. This function is not available in the Madcam 4X version. Two problems: First,it did not produce g-code to the a or b axis using the mach-3-metric-5-axis PP. Second, the 5-axis tool icon is not activated tor the Madcam 4X version. Do I need the 5X version of of MadCam? Can the Madcam 4x work the 5th axis of the head-head machine?
Summary:
1. Need help setting up the 4 axis to be tangential to the profile curve
2. Do I use the 4X / 5X profiling function or the 4 / 5 -axis cut along a line function to create the tool paths?
3. Help making sure that my PP is set up correctly. I used the mach-3-metric-5-axis as a template
2. Can this be done with Madcam 4X or do I need Madcam 5X?
Ultraviolet
